Good Lord, It's a couple of Fords (1964 Ford 2000 & 1949 8N)
legopnuematic
Licensed Junk Dealer
MO
Spencer
@CountKrunk thank you. Andy and Greg laid things out pretty well on the capabilities of these tractors.
The Ford's lack a low enough first gear, five or four speed to run something like a tiller. Even with a Sherman or other over/under drive it will doesn't really get things low enough if it's tough soil. Something like loose sandy stuff it might work if you let the tiller push the tractor ahead. A select-o-speed might be able to, but it's a select-o-speed and those can be a nightmare.
I believe that a Sherman can only be installed with a 4 speed, I do not believe it will work on a 5 speed.
On the N series (9,2,8) they lack a live PTO and live hydraulics. The PTO must be running to run the hydraulic pump for the 3pt and the clutch must be out. The hydraulic pump does not make enough volume to run a remote, an auxiliary crank driven pump must be added to run a loader or any remote equipment. An overrunning clutch must be used with high inertia implements like a brush hog as it will push the tractor forward when you clutch in without one.
The 1953+ tractors like the NAA, Jubilee, 600, 800, 2000, 4000 etc have live hydraulics, and with a 5 speed a live PTO (dual clutch) was an option. They do produce enough volume to run a remote or two if added for basic remote uses.
So a 1953+ Ford is much more advanced than an N series, but the N tractors are very capable for what they are and extremely plentiful and well supported with parts.
The good bad thing with the fords is they have a fairly high power output for their size, comparable power level offerings from IH or JD typically weigh about 2x what the Ford's weigh. The use of the 3pt provides better traction, but drawbar to drawbar the heavier tractors are better. Basically any implement sold at a tractor supply, rural king, bomgaars, etc will be sized about right for an old ford.
legopnuematic
MO
Spencer
The rears are loaded on my 8N, I'm assuming with calcium chloride, and it has done what what calcium chloride does best:
I don't think the tube is leaking, this is water from rain that has filled the tire outside of the tube.
So if I decide to do new tires I'll need new rims.
legopnuematic
MO
Spencer
Old ring gear removed
New input retainer and seals installed and reinstalled on transmission.
The throw out bearing was also used on 1988-90 Medium duty GMs with one transmission option.
New ring rear installed
New pilot bearing installed.
legopnuematic
MO
Spencer
Cleaned and rebuilt the carburetor. Almost. The old float had liquid in it so a new one is on the way. So it's assembled minus needle, float.
Moderator
I believe my tractor was the same way. When I got it from the local tractor dealer, it had brand spankin' new rims, but with old rotten tires. The guy I talked to said a local fella had it setting in his barn for many years.
legopnuematic
MO
Spencer
Late to the party, some of those old CR seals have the part number molded in the rubber lip. Need a magnifying glass to read them.
Good information! I don't think I tossed the old seal yet, I'll have to give it a look and see if it has a number on the lip.
legopnuematic
MO
Spencer
Interesting. I’d have a hard time putting old tires on new rims, unless if they were really nice old tires.
What is on mine now is ok as is, but if a tube pops I’m not messing with them. I’ll get new rims and tires, or good used, but it seems people want as much or more for used rims and tires than what you can buy new ones for.
About $150/rim, $75/tube and $300/tire, not cheap, but would likely last forever with my use and being kept inside.
Moderator
As dry cracked as my tires are, I'm confident that I can get another decade or so out of them. They still serve their purpose just fine.
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
@bucket what no burnouts or sub 14 second E.T.s......WTH.......lol
legopnuematic
MO
Spencer
I had discovered the ‘900’ hours is 900 hours since the proofmeter was replaced in 1999-2000 based on the laser etched date. That makes more sense than 900 hours since 1964.
Some organization
Started on the hydraulic pump.
The whole reason for all of this, the needle bearings fall out and get jammed up in the pump drive and driven gear and break the camshaft. I believe the tapered roller bearing wore quite a bit, then allowing the needle bearing to wear and eventually start coming apart. No cage on the needle bearing.
legopnuematic
MO
Spencer
Pretty good step on the small end of the race
Asbestos?
Went to fire the welder up to weld the race to shrink it. Dang welder didn’t want to turn on… Anyone notice anything?
jw23655
