codfish
Drive a hybrid. I NEED your gas!!
- Jun 9, 2022
- Newfoundland
- gary
- K10
Speedo started jumping around a little, then worked intermittently, then finally died.
Unhooked cable from transfer case yesterday (np208), and ran it with a drill. Speedo functions.
Where the cable screws into the transfer case, there are 2 90° adapters. Is this normal? 2 adapters screwed together? Couldn’t separate them. Didnt wanna torque on them too much and break something. Not sure if these are still available new. The little cover holding in the Speedo gear was actually turning while trying to unscrew the adapter. And do these 90° adapters come in different ratios? Speedo was fairly accurate before it died.
Second question. IF I have to remove the output housing on the transfer case to replace the drive gear for the Speedo gear, do I have to remove the driven gear and its cover first?
Using the ole pocket computer for a Speedo right now lol
Thanks
Codfish
Thanks
Codfish
