cleaning the wiper motor
84GMCSierra
Supporting Member Air Force
Central Arizona
C2500
Good Morning everyone. I was wondering if there is a way to clean the wiper motor on my 84 Sierra? I live in Arizona, and although it's not near as cold as other states, my wiper motor is very slow when I first use it in the rain. I think I read somewhere that the old grease in the motor might be the culprit so I want to try a clean and regrease before replacement. My motor has the washer pump on it, but ti doesn't work so will try to see if it's plugged while I have the motor cover off, if possible.
84GMCSierra
Central Arizona
C2500
Both High and Low speeds on my motor are the same. I tried to upload the video but it doesn't show up when I click on "attach files".
fast 99
Spokane, Washington
wiper transmissions are most likely dry as well. Remove wiper linkage, 1/8" drill housing on back side, use a grease needle to lubricate. Seal hole with RTV.
84GMCSierra
Central Arizona
C2500
Another question about the motor. Looking at new ones online there's a ground strap on it. Mine doesn't have one so should I add one or does it matter?
ali_c20
Austria
Alexander
C20, K5
Put one on, good ground is crucial for proper function.
jw23655
