2000 6.5 turbo on a 82 6.2 diesel?
Jermu97
Finland
Jermu
3/4 ton 4x4 Suburban
6.2l
What the others have said, but also looking at the condition of things under that hood, I'd go through that turbo before using it. Some "bro" has cut up the inlet to the turbo and for whatever reason turned the wastegate vacuum controller to point upwards. There's just a lot going on in that engine compartment that makes me a little wary...
And truthfully, you shouldn't use that turbo to begin with, it does not fit the engine. Go to an hx35 if you want power AND reliability, because you don't really get either of those with that gm turbo.
73jacobs
