Lowering a 1984 silverado
xm20k
Girard, Ohio
4/6 No notch. replaced the heavy spring packs for stock half ton springs, had to move the rear brackets to the forward holes in frame. 20x8 245/40/20 and 20x10 305/50/20 Nitto drag radials
Man I gotta fix that broken lower fender bolt it annoys me to no end every time I see it sticking out.
Carb'ed Vortec 350
.....Man I gotta fix that broken lower fender bolt it annoys me to no end every time I see it sticking out.
But it waves to everybody as you drive down the road...
Aj Farias
Adilson
Silverado 1500
Not sure what the limit is, but this is how mine sits. I don't have a notched frame
How much do you lowered and what you did to it to lowering like that . If possible parts you bought it and links, i like like that and i dont want to do a catch to it.
Aj Farias
Adilson
Silverado 1500
4-5" if you plan on using it as a truck.
6" flip if you don't plan on carrying much weight. Otherwise you'll have to notch to tow/haul more than a few hundred pounds.
Im not planing to use as truck, more like a weekend's ride but also i dont want to lowered a lot because its a long bed. I want more or less for the tires to be even with the fender or like a finger space front and rear.
Aj Farias
Adilson
Silverado 1500
We did just the axle flip in the rear and no notch is needed and it rides perfectly fine. A little truck like even.
Front we did 3" spindles and 2" springs. This was a little low for in the front so 1.5" springs were put in to level it out.
For me because its long ved i wabt to go i bit higher than yours?
If you dont nind send the link for the parts you ordered for.
Aj Farias
Adilson
Silverado 1500
We are about to do the Westen Chassis 2/4 drop in a week or so, last of the parts ordered in December just arrived last week! We will update y’all
Randy and E
Any update on your project?
Scott91370
Burleson, Tx
Scott
Sierra1500
I used a generic rear flip kit but this one is very similar:
Front:
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
When time comes, I'm thinking spindles and shackles for the c20 because I still want to do truck stuff with it. It's a ¾ ton after all...
noah crook
