fofiddyfo
wisco
R3500
My middle son got his learner’s permit, and besides the family minivan, has now talked me into driving the dually and my Lexus :D Just look at that grin; worth the price of admission just for that!
Me and the boys took the square trout fishing today; that’s been a long time in the making!
K20SM465
Darryl
Got the wood sides off, the homemade headache rack, then the drop in plastic bed liner. Then I took what was left off of it and remove the lift cylinder and pump. Pressure washed it then gave the Rochester some tune up in a can, put some fuel in the tank and on the second turn of the key I was jumping for joy. Now to get the cab floors and doors fixed and play with my new to me truck while I fix everything else.
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Impatient as usual, so I went for it since I really want to get this back together because I have parts spilled all around my property. I still need to paint a little under the hood so I am leaving the paper until that’s completed. I had this paint leftover from the z28 project 30 years ago. This blue looked awesome on that car. The blue stripes look okay for my 20 footer.
Can't wait to see the finish Brother!
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
So back with the truck. OBD1 is reading code 21.
I was initially planning to redo the torx up 1/4 turn but not sure since code 21 is TPS malfunction. Typically this means idling high from what my research has shown.
The truck is running great after the most recent adjustment but service engine light is coming on after the initial idle down and staying on, and that's bothering me.
Should I try to adjust the TBI torx screw again? I do not have a light to read RPM's or an auto meter currently. Or should I begin looking for another TPS? This would be the 2nd TPS I install on this truck, and I have heard some aftermarket ones are garbage from the start.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Initially the post said...light to read MOM's...
I edited it to correctly read RPM's
LOL
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
I went ahead with my initial plan to adjust idle again. When the IACV was unplugged I adjusted the torx in the TBI up a quarter turn. Plugged in IACV then disconnected the battery for 5 minutes.
Reconnected the battery and fired her up. It starts the same. I drove it. It is driving great, but as before, the service engine light is on after ignition drops idle.
Selo
Greensboro nc
Replaced the u-joints, replaced trans oil in the 3 speed, replaced the diff. oil, changed the engine oil and filter.
Windshield replacement is next.
Selo
Selo
What gear oil did you use in the transmission,was it gl4?
1STLS1
West Phoenix AZ
MIchael
Put it in the garage, pulled the brush guard, bumper and unbolted the core support. dropped the wheel houses out off it. I am getting ready to swap engines along with changing the a/c evaporator and heater core. Reseal the case, new blower motor, new compressor, condenser, accumulator and a/c hoses. It will be done and hopefully I will not have to deal with it for a while.
Camar068
Air Force Supporting Member
10 yrs Air Force
got a rear painted bumper with dings (no rust) and what not for the hunting truck. Gonna drop it off tomorrow to have the lower corners cut out and have him weld in some corner steps like the newer vehicles. $85 delivered and guessing less than $150 for the cut/weld and a little metal.
Make it easier to get in when the tailgate is down.
83Stepper
Massachusetts
Chad
Found a set of 2 15x7 and 2 15x8 rims off Marketplace for dirt cheap. Dropped them off at Wally World to get some new sneakers on them before I was able to get any paint on them. Shot them with Argent Silver. Cleaned up the deep dish trims with some 0000 steel wool and Wenol. Tossed them on tonight and wow, what a difference!
Tank6x2
You’re Awesome Know That!
Lifetime Supporting Member
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
Last few weekends Working away at the shaved firewall, removed steering linkage and crossmember support bracing, started stripping paint on the frame rails on “ Stormin Norman “
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
pics when you are done???......please
gmbellew
Kansas city
glen
suburban 1500
Code 21 is high TPS voltage (>1.25v at idle). If you opened the throttle enough with the min air screw, it could be the TPS voltage is >1.25 at idle. If the idle RPM is good, and the IAC is less than 30 (warmed up fully) with how you have the min air screw, then bend the tab on the TPS to get the voltage down below 1.25v, preferably down in the 0.5-0.75v is range.
You can back probe the sensor to check it's voltage if you don't have any scan capabilities. And there is a diagnostic chart for code 21 in the fuel and emissions manual if that doesn't resolve it.
hauto85
