78C10BigTen
pennsylvannia
C10 BIG TEN
Spent the day tinkering with getting my new breather scoop (compliments of RustyNail) mounted and adjusted just right. Took 3 trips to the local hardware store for various bolts and nylock nuts and a stick of fine thread all thread to make some new linkage but finally got er done! Tomorrow will be making some adjustment cuts to my summer hood to accommodate the new breather! Looking forward to laying those butterflies flat at WOT!!! Goin' to light em up and smoke em!!! I need new tires anyway! LOL:cheers::cheers::cheers:
Just hope you secured that very tightly so the carb dont swallow it at WOT. OPEN ER UP!!! :happy107:
Big Chip
Michigan
Kevin
C35
I about crashed it when the hood came unlatched in flight. Thankfully I was only doing about 45 on a 4 lane road and I was in the outside lane.
78C10BigTen
pennsylvannia
C10 BIG TEN
Good thing your ok! Holy crap that musta been a ride!!
Poppy 87
Bloomingdale GA
R10 Silverado
Ouch! WTF?
Sent from my XT1254 using Tapatalk
Big Chip
Michigan
Kevin
C35
Ouch! WTF?
The spring is missing on the secondary latch so I don’t know if it was gone before or departed the scene when it jiggles itself loose.
78C10BigTen
pennsylvannia
C10 BIG TEN
It wasn’t terrible but it was a real surprise. Luckily I was able to get it bent back enough to latch it and continue journey!
Too bad your a ways away, ive got a decent straight hood in storage.
Big Chip
Michigan
Kevin
C35
Don't sell it just yet, I may be willing to travel if I can't find a good one around here. That was an aftermarket Taiwanese made hood and it's pretty obvious there's a difference between the factory and aftermarket metal. I still have the hood that was on it but the ironic part is that the biggest reason I changed is because it has no provision for the secondary latch. No hole for it in the hood. It's a '78 and older hood and I suspect it's an early one.
Poppy 87
Bloomingdale GA
R10 Silverado
Are the 78 and earlier have the hood release thru the grille? No cable release from in the cab
78C10BigTen
pennsylvannia
C10 BIG TEN
The one i have im 90% sure its oem later model i pulled from the local junk yard. Has the accent line around the front edge. Has VERY minor rust also.
78C10BigTen
pennsylvannia
C10 BIG TEN
My 78 has the inside release as well as outside release, silverado trim.
Poppy 87
Bloomingdale GA
R10 Silverado
My 78 has the inside release, silverado trim.
Sorry, I wasn't very clear, that was a question not a statement. I had a 73 years ago with no inside release. Don't know when that changed. The 20 beer buzz is not helping!
Turbo4whl
Downingtown, PA
Wayne
Very nice clean install! Duel feed, double pumper and center hung floats. All those guys posting in other threads about how they don't like Holley carbs..... burn them tires!
iamberttt
