GM Axle Questions
Burbinator
Evan
Suburban K1500
Ok so I’ve gone through another forum discussion and I know what it is. But I don’t know what it’s out of. I have a GM 14 bolt, Semi-Float, 10.5 inch gear, 6 lug rear axle.
It’s standard width in my Squarebody burb, no wheel spacers like it’s from a van or dually. So… what vehicle might have it? I’m asking for future when I inevitably need to do brakes. Only one pic for now.
Burbinator
Evan
Suburban K1500
legopnuematic
Licensed Junk Dealer
MO
Spencer
9.5”, not 10.5”
Measure the track width of the front and rear, a squarebody axle will be narrower than the front track width, one from a heavy half K1500 GMT400 will be wider than a squarebody rear, enough so that the front and rear track widths will be almost the same.
If it is a squarebody rear, then someone changed the axle shafts to six lug, as was discussed in the other thread, that 9.5s were only used on 20/2500 series squares, and all 8 lug.
GMT400s they were used in 454ss trucks, K1500s and 2500s, in 5, 6, and 8 lug flavors and at least two different widths.
For the brakes I’d guess whatever a say 93 K1500 heavy half truck uses is what you need, measure drum and shoes to compare and verify.
Burbinator
Evan
Suburban K1500
Here’s this pic it it helps see track width. I’m on vacation so it’ll be a bit before I can measure for certain. I do know the front and back wheels match offset/width.
Burbinator
Evan
Suburban K1500
It won’t upload I’ll try in a bit. But on the 9.5 vs 10.5 debate we figured out that the 9.5 diff cover shape doesn’t match like at all. But the 10.5 does
nvrenuf
Mobile, Al.
Note the squared off sides and hard triangular shape to the top and bottom, the axle in your pic has a very round cover.
As stated here, you have a 9.5” semi floater 14 bolt not a 10.5” 14 bolt (full floater).
Burbinator
Evan
Suburban K1500
So if it’s a 91 suburban is this axle out of a GMT400 or something else? It looks like equal width front and back
Tennessee
Most likely an OBS axle. Brakes would be for a 97 K1500 with 11" drums. If you'll measure between the backing plates I'll measure the one I swapped into my 96 Tahoe and compare the two
Burbinator
Evan
Suburban K1500
Sounds good. I should be back around Tuesday then I can measure
Burbinator
Evan
Suburban K1500
Could it be a 3/4 ton semi float 8 lug converted to 6 lug?
Original
