JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Just got back from the machine shop, the heads are good to go. Not a quality issue in site per the shop, they’re actually built very well. So I guess with that said, I give my tip of my hat to Brodix.
Now, I’m coming to terms the fact that I actually have to take a perfectly good running truck apart. Kinda gave me pause today, but it’s something I’ll get over very quickly as soon as I start ordering lots of really cool parts. Hope y’all are doing great.
I have now finally decided. Chad, I think your rig is best looking with your rally's. Beautiful truck, as always dude.
Sad Sack
Nebraska
Goober
C15
I'll try swapping the pinned wires around.
When I bought mine, I had a 4.5 amp draw on it, battery died overnight. Pulled all fuses, no change. Pulled the alt connector out - draw went to zero. Compared it to a replacement connector and wires were reversed. Hmmmm...It was obvious the connector - wires were recently worked on. PO wired the new alt connector wrong and once I reversed the two wires the draw was zero, battery stays charged, no more electrical issues and no more worries. Got lucky.
Was obviously one of those things the PO should have mentioned on purchase. Took it home and next morning DAADN...dead as a door nail.
Carb'ed Vortec 350
Well 99.9% of the time when I do maintenance service or do some fixin on the Suburban, it all works as planned. However this time it seems as though I used too much brute force removing the heater hoses from the heater core and it is now leaking. I had replaced the leaky OEM core about 20 years ago and it worked fine until I broke it the other day. I ordered a new core that should be here early next week so I can go to fixin on it. So this is a "what I'm gonna do to my Square futurely" post...
I used to use the brute force method until I discovered the hose removal pick-hook
Terlingueno
Fictional Western Sage
Far West Texas
Skeeter
K20 Suburban
350/SM465
Had I used my noggin just a teeny tiny little bit, I should have cut them off, since I was installing new hoses anyway.
Currently looking for a decent used hose pick tool...
Another way if they are stuck slit the hoses lengthwise at the heater core,then peel the hose open. Always make your hoses a little long that way if you have to slit the end,you just shorten them an inch.
HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
You can use a small pocket knife or pen knife under the edge of the hose too, if you can get that tool in the space. Picks or hooks or small straight blade screwdrivers (I have a couple I also use for popping wiring harness plugs loose) also work well.
Ajax19
Socal
Ajax
Curious what's y'all's opinion on bronze vs paper fuel filter for the qjet I run one filter just before the lift pump and one after the mechanical pump(I plan one deleting but was some I set up so I can see the fuel flow under hood)my filter inside the carb is probably about due so thinking about swapping to the bronze style
Strick
Dunn, NC
Harold
C20 Crew
Well, it's a Square in it's bones. Dad's ole 55 6100. I'm getting some free time & have received marching orders from the ladies (wife & daughter) to get it running so that we can use it for Christmas decorations again.
Happy Santa
Shorty81
Baby Boomer
North West ohio
Darren
Happy Santa
That's a freakin' awesome truck!!!
Make one out of a cheap junk straight screwdriver. Bend the end over 180* I bent mine about like this,I took a buffing wheel to the end first to knock off all the sharp edges. Dont remember if I heated it first It was many years ago,use a cheap skinny screwdriver. I had a Snap On one but lost it so I just copied it. The funny thing is I found the one I had in the first place.
Terlingueno
Far West Texas
Skeeter
K20 Suburban
350/SM465
Happy Santa
WANT!!!!!!!!
Travlr
Central Utah
C
K20 Camper Special
Happy Santa
I don't believe I've ever seen a grill like that. Certainly most '55 have a different grill. Is it because it's a one ton?
I just googled it and it says Chevy had both the old body style and the new one the same year... and a 6100 truck is a two ton. Whoa!
hauto85
