ChuckN
Bellinham, WA
Chad
Put these mud flaps on that I’ve had kicking around. Got brackets from the junkyard recently and thought I’d see how they looked. They are net required where I live and I don’t drive this truck on the highway. So they would mostly just be for protecting the paint on the truck.
But I’m rather concerned about how close they are to the wheels. Even with the anti-sail brackets they just look to close. What do you guys think?
IMHO, if you’re moving forward, wind would be pushing them back and further out of the way. Though someone may tell me I’m wrong.
Moderator
Perfectly fine, unless you back into a stump or something and force the flap into the tires as you are reversing. In which case, it'll rip the flap off. But, that can happen even if the flap were mounted further rearward. It's just the nature of flaps on work trucks.
Johnny Atomic
Little Rock AR
Johnny
Sierra Classic 1500
Sanded and primered the bottom of the tailgate before the rain hit.
Anyone know how to pop off the tailgate insert? That would be easier for me to sand and paint.
I tried a million ways to shine up my tailgate band. Due to that coating or anodizing (or whatever it is that GM put on there ) after I got wet it always went back to looking streaky and white, like i had done nothing.
Absolutelly the best way I found was to polish it with metal polish, wipe it down with lacquer thinner and do a single thin wet coat of cheap spray can clear gloss lacquer. The lacquer seals it up and fills the pores of the coating. Lacquer is very thin and shrinks a large amount and therefore doesn't leave it looking like a thick plastic coating like other clear coats, It just looks correct. I did mine 4 or 5 years ago and it stilll looks as good as the day i did it.
Another option I've seen guys do (only seent it, never done it myself) is use the oven cleaner in a yellow can to "bake" off the anodizing. Once done, then just polish up the bare aluminum to whatever amount of shine you desire
Bronze Knight
USA VA
Robert
Yeah I’ll hit the tailpipe before the mud flap in that case. I’ll carry on and do the other side and the take her for a drive and see how they do/look.
Camar068
Air Force Supporting Member
Kentucky
10 yrs Air Force
Paint it with epoxy paint,sprinkle Sand in the paint in the footwell while the paint is wet, so your feet don't slip out when your shoes are wet.
Good idea. Might have the welder put a solid bead on the outside and call it. That or if ur sh|t slips...it's on u lol.
Sad Sack
Nebraska
Goober
C15
Got the headliner ready to go in:
The board was iffy, but she survived the "cleaning". And now for cutting the visor and dome light holes.
82sbshortbed
Why like that?
SE Texas
Doug
1500 shortbed, 1500 longbed
Got the tailgate sanded and back on with the insert. Not the best but not too bad.
gmbellew
Kansas city
glen
suburban 1500
got a code 13 and then a code 44 on the 1990 burb. checked the data from ALDLDroid and BLM/INT are all over the place and the O2 was being really weird. stuck low, then worked back high, then oscillated like normal, then stuck low, etc. O2 volts on a cold engine with key on was right where it should be, so wiring was most likely good and ECM ok. figured O2 is cheap and easy enough to throw a part at it, as it was the likely suspect. disconnected the battery for a bit to clear codes and reset the fuel trim learn to start from scratch vs whatever it was doing with the bad O2 data after I dropped in the new O2 sensor. I took some long drives today and everything back to normal.
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Not a Chevy, a 1991 Jeep Cherokee, got a code 13 this week as well. Mine was MAP sensor. Still not right, more investigating is involved for me.
jw23655
