What are your emmissions testing laws in your state?
Moderator Administrator
With my digital gauges its extremely easy to "hide" miles if necessary for these purposes :D
Driver4r
Nebraska
Trevor
k10,c20
None in good ole nebraska
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
A bunch of ********.
Jims86
Patterson,Ca
5.7 TBI
Unfortunately the speed sensor is in the speedometer and needs the cable connected to get a reading off the spinner. I can pull apart the gauge and remove a gear to keep the clocker from adding miles, just a pain in the ass to take apart and put back together. I have done it though.
You have a cable?
heavyleft
Fayetteville, NC
V10/K5
350ci
Here in middle NC its a visual inspection but thanks to employment with Uncle Sam, I retain residency in TN where there is no emissions or inspection (at least not in the County I call home) plus two of my vehicles have permanent plates so no registration or anything :)
Jims86
Patterson,Ca
5.7 TBI
Yes. Why? Thought you knew that. Speed sensor is in the dash, you told me how to test it. :roflbow: :roflbow:
Derrr.....ok. if you want to pull some wool, the have a vss that will go inline with the speedo cable
towman
harrisburg pa
jay
v10
I can only drive it one day a week registered as an antique. :roflbow:
Last year I was under 5K so it was exempt. I am right on the line with that. Regardless, it still needs a visual inspection for the parts.
i wish i didn't but i do emission tests, with just being a visual are you missing stuff?
Moderator
No inspections here. There was talk of it in Franklin county about 10 years ago, so I moved to another county.
87sierra
Pennsylvania
Sierra 2500
5.7L 350 TBI
ya well you have lawyer:upyours: to thank for emission standards in PA i took the test and the rules and regulations are so messed up
unless u live in carbon county and any other county that doesnt have emissions we all have the same problem and it only gets worse the newer ur vehicle
No, it's all there, just a bit worn out here and there.
BigRuss
Salemburg, NC
Reece
Custom Deluxe C10
305 5.0L
My truck is supject to saftey and visual checks (mirrors and lights) my daily driver is the same but has to be plugged in to a computer... since I moved 1 county over I don't have to have emissions tested but they check my exhaust for illegal mods (no cats straight pipe)
OMG Its Bill Fuggin Murray
Gurn
