- Feb 5, 2014
- Kentucky
- David
- K10/LM7 5.3/4L60e/np208/3.73/32"
- 10 yrs Air Force
Got an 86 K10 with a 75' 350 in it. It had an 87' in it until last month....lost oil pump. Anyway, after the engine swap, it had the distributor that came with the used motor. It had the 4 pin cable that goes to the ECM (from what I'm reading). It left me stranded so I stuck the 87' dist. in it and vroom.....fired right up and I've been on the road since. The 87' doesn't have the "ECM" connector. Both have vacuum advance.
While installing the 87 I noticed how thin the pins the weights pivot on were compared to the 75'. They are half the size of the pins on the other, while the weights have the same size holes as the other. I thought wow....not secure and a lot of slop to play with the timing.
So here's my question.....Can I pull the shaft with the "normal" pins and put it in the other distributor?
Trying to save as much $ as I can as I'm about to go get a 5.3, hopefully this week. Be a while to install though.
Thanks In Advance
'maro
Thanks In Advance
'maro
