Doubledingo's 2005 4x4 Tahoe LS
Carb'ed Vortec 350
After getting it home and running some errands. Only pic thus far...
Enter, The Hoe, 2005 Tahoe 4x4
Oops, I lied, this was sitting at a light after some miles on the way home...
Hadn't found a gas station yet.
At the station, added a bottle of motor purr fuel injection cleaner and topped off with high octane. Got the walkie-talkies ready, and we headed home.
All freeway going home, some gridlock, mostly free-flowing, and going up and over a mountain range.
No issues. It hauls @$$. Cruised 80-90 the whole way.
Carb'ed Vortec 350
The fob didn't work, had to get a new one and get it programmed. Daytime running light bulb is out, got new ones along with new wiper blades.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
What fob did you buy? I need to get one for my daughters ‘06 Z71 Hoe
Carb'ed Vortec 350
Before deciding to bring it home or not, I did a lengthy look over top to bottom, front to back.
Test drive was short, but good enough, was able to get a decent feel for how it drives.
After that, crawled under and checked for leaks, rust, damage, and any other thing that might cause alarm. No leaks, no damage, nothing jumped out.
I did notice a clunk in left front, only over bumps, but the suspension seems solid. Will be investigating the cause of the clunk.
It rides smooth, brakes good, steers responsive for an suv.
Carb'ed Vortec 350
I went to the local Ace/True Value hardware store that cuts keys. They had the new fob, and programmed it in the parking lot. It was GM037 in their system.
The new fob looks like the original too
CalSgt
CA
Casey
I’m going to have to give them a shot!
Last fob I got for my ‘06 Duramax was close to $100 at the stealership
Carb'ed Vortec 350
A quick backup...
I called on Friday to see if it was still there, it was. I asked if they'd hold it. Yeah, with a deposit. No deposit, sorry, but we'll be there in the morning. Okay. Then got a text confirmation.
Headed down, stopped for breakfast and texted them telling them that we'd be there soon after they opened.
Got there, we saw the vehicle being driven away. I was pissed. They assured me the guy was just test driving and he was there first. I said bs, I had an appointment.
That told me they don't keep their word. Oh well. It came back, we test drove it, and by the time we got back that other guy was gone.
Carb'ed Vortec 350
It was 81 dollars, and worth it. I was upset that the old one didn't work, not sure why it didn'twork, all is well now.
I left the GM dealership in 05 so cannot give direct testimony for an 07 Tahoe,but through 2005 we had plenty of clunks that were caused by the steering intermediate shaft,they can sound similiar to a ball joint,going over bumps. I'd inspect it if you don't find something obvious.Just if the grease in them dries up,they will clunk on bumps.
Carb'ed Vortec 350
I left the GM dealership in 05 so cannot give direct testimony for an 07 Tahoe,but through 2005 we had plenty of chunks that were caused by the steering intermediate shaft,they can sound similiar to a ball joint,going over bumps. I'd inspect it if you don't find something obvious.Just if the grease in them dries up,they will clunk on bumps.
This one being a 2005, what you describe is probably what it is. Will know more when I can get it up and jack stands and front wheels off
Turbo4whl
Downingtown, PA
Wayne
Amazon has the fobs, inexpensive too.
GM 2000-2006 programming.
* Key in the ignition, (off)
*Hold the driver's door unlock button.
*Turn the ignition on/off once, do it again second time, on/off fast.
* Horn beeps
*Hold the lock and unlock buttons on the remote. This takes a few seconds. Maybe 15 to 60 seconds. Horn beeps. The fob is programmed. If you have a second fob do it now. This also erases any other fobs that were programmed.
* Turn the key on to end the programming.
Side note, the battery needs to be up. A battery at 12 volts will start the vehicle. To program, 12.75V or more will work.
Carb'ed Vortec 350
Try a new fob battery, 2032. You'll have to program them both at the same time.
New battery didn't work. Tested the fob with fresh at hardware store, bad fob.
blue10
