2 wheel drive s10 blazer
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
ya it should have a tv cable mine is a weird one it wraps around the throttle lever backwards
Swims350
Logan WV
none
oh ok mines like that too I thought it was the throttle cable.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
my tires showed up today 245/50x16
Swims350
Logan WV
none
that's cuz when u see em you gonna kum ho. lol
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
so it might take a little more work than I wanted
I am thinking I need to cut off the motor mount perches and lower the motor for better header clearance.
the blazers had the perches that raised the motor to give a better drive shaft angle due to the shorter wheel base than the trucks.
I am going to lower the rear 3'' so I don't think taking the perches out will hurt me. I think it may actually help me.
and I think I need to change the throttle cable and tv cable but not sure on that need to test fit the 4.3 ones
Carb'ed Vortec 350
That blazer will be a fun ride when you get it going.
LOVE when new tires arrive at my door!! :) and 320 is CHEAP for a set of tires regardless of size! :eek:
Swims350
Logan WV
none
I thought he meant per tire lol.
yea I bought stockers for the wife's car local and it was almost 400 for hers and they are 225/60-16
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
I shop around a lot and most of the time end up going to ebay to find the best prices
summit ,jegs and a lot of retailers have ebay stores
they have to price stuff to compete so I love ebay
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
ok solved my header clearance issue did not have to cut the motor mounts off
we had a discussion with a 2 pound hammer it decided to see things my way
got a new tv cable and throttle cable for the 350 and dug up a 350 tbi
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
wheels showed up today and I just finished mounting the tires
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
come to find out the newer s10s have a smaller hole in the center for the hub so theses wheels will not fit without modification.
I have to enlarge the center hole slightly to make them fit. not sure yet how I will do it .
a flapper wheel on a die grinder or a hone maybe both
I could have the hubs and the axles turned down to fit the wheels but I think fitting the wheels to the truck will work out better for me
60Denais
