RanchWelder
- Jan 14, 2023
- Earth
- Blazer
- 350ci
My 14-Bolt rear suspension included Leaves being swapped from 52-inch stock springs to 60-inch stock springs.
Added extra long perches, in case wanted to move the axle back further. (It will not be possible, more on that later).
The extra long 3-position perches allowed me to remain close to stock height, so long as removed the Overload Flat springs, from the stock GM 60-inch 99'Surburban spring pack.
This required using a replacement spring pack bolt, as the older one is now more than 1-ich longer than the pack. Planning to add a leaf, under the OEM rear stack, for added pack stability. The overload is important on a pickup truck, so get professional advice before eliminating it on your build.
If the Blazer ever had enough OVERLOAD, theoretically, the lack of overload flat spring, could cause the springs to crack at the center bolt location, from over bending in the reverse direction, without support... The added short bottom leaf should help out, if needed.
My rig is set up for a fifth wheel hitch, so keeping tongue weight reasonably should not be an issue. The sliders could also support a Goose Neck, if wanted.
Have never towed with any short wheel based vehicle, so keeping stock height for this modded Blazer, is especially important.
My tires are HD road style treads, not over wide mud-er tires. No 35's. The corporate 10-bolt uses GM six lug x 15-inch wheels.
The rear 14-Bolt uses 8-lug x 16-inch wheels. Tires are sized to match within 1/2-inch diameter, using good quality road, all-weather radial tires.
The bed always has 2 spares on board.
______________________________________________
Skyjacker SC125 Springs for the front end.
https://www.summitracing.com/parts/sja-c125
Summit Racing matched the price from another web store!
Make sure you look around for the best price before you pull the trigger.
My Summit Order came directly from Summit, and the shipping was fast.
Ordering from them, I was able to confirm these springs did not already have OEM bushings pressed in.
This would have caused another step to remove them, before adding the Kevlar reinforced Urethane set up from ORD.
Pressing out OEM bushings is not for the weak of heart or weak of bench press.
It took 2 grown men, (one is nearly a giant man), and a 30 ton press to replace the bushings on the rear 60-inch springs. Buying springs without bushings is the way to go, if you choose the following non-stock bushings.
Summit made the purchase easy. They also sent me spare bushings from Skyjacker!
When my order came, parts I did not expect showed up with the springs. It's OK, will share them or save them as backups.
Skyjacker specify a 2-inch to 2-1/2-inch lift, however my truck has an added front Cow Catcher.
Easily 190 pounds of added weight way out in front of where the old bumper used to be. I made a deck so I can stand in front of the grill to work on the truck. This pushed out the catcher, so WHEN hitting an Elk, the bars have a ways to go before they ruin the grill and hood.
This rig is not designed for rock crawling, so adding length to the front spring pack was not required. The expected lift is around 1-1/2-inch max. We'll see.
In any event, the lift was intentionally avoided, so the truck tracks well with a fifth wheel hitch, when required.
The frame shackle bushings and front leaf spring bushings, were shot. The OEM Springs are 38 years old.
ORD sent me a set of replacement leaf spring frame mounts.
From This:
To This:
https://www.offroaddesign.com/catal...-front-upper-shackle-hanger-kit/category/417/
Here's where the frame required some grinder and cutting wheel work on those pesky Frame Rivets:
My fender well had to be trimmed back a small amount so the 5-inch De Walt grinding diamond wheel could get to the frame rivets, from the outside.
Careful not to dig into the frame at a hard angle.
ORD's bushings required an additional 1/8-inch diameter to the frame holes.
I trimmed them towards the top of the existing holes, so the bolt holes aligned with the OEM rivet holes. Each rivet hole had to be drilled out for the grade 8 hardware.
The die grinder made locating the new upper mounts easy.
All but one hole required to use the new bushing mount as a drill guide.
That one extra ream did ruin the brand new cobalt bit, by chipping as it relocated the missed hole. I was able to complete the other side with the same bit, but would not recommend using the mount as a drill guide for any hole that doesn't match up.
My current Shocks are Monroe set with helper springs over the shock body.
They are designed and sized to replace the OUTER shocks and added extra support when the old leaf springs were worn out. ORD advised measuring the truck with new 4L80E and rebuilt engine, after the spring install, so the exact shock could be ordered for the INNER TALLER shock mount.
Good thing did not go wild and grind off the taller 4 shock towers when opted to eliminate 2 of the 4-shocks earlier. (Monroe and other professionals advise the 4-shock system is outdated due to advances in shock technologies.) YMMV
The new shocks get measured after all the engine and transmission install, so the exact ride height can be averaged for new taller shocks later. They will be using the inner OEM mounts, and no longer using the outer shock mounts.
The front OEM leaf spring bolts were bent from the rotted bushings bottoming out.
They had to be sliced with the Diamond wheel.
ORD sent me quality grease-able bolts and new shackles:
(Had no idea Summit would include them).
ORD has designed improved bushings with Kevlar.
https://www.offroaddesign.com/hd-front-shackle-kit-for-67-91-gm-trucks.html
I called them to order the exact set without the extra rear leaf lower bushings, winch come included in the kit above. You'll have to select exactly what springs used, so the bushings match. Choose your springs FIRST. Then order after speaking with ORD.
Make certain you order these parts carefully, so you do NOT end up with an un-used extra $40 bushing, due to overlapping parts seen in these pictures.
Next up is the leaking gear box:
Found this seller on eBay had the best price and excellent customer support rating for a BRAND NEW, NOT Re-manufactured unit.
https://www.ebay.com/itm/116197934107
$275, on sale from $325. Wanted to keep my old box, in case I can repair the seals and have a spare for the future. Never rebuilt one before. Figured tearing one down might be educational, at the very least?
Hopefully will learn what not to do during the replacement of the $20 seal kit.
The tighter turning unit from Borgeson was a bit out of my budget. Want one... oh well.
The steering shaft with the rag-joint had to go.
The forum had a suggestion to use the C3500 GM Style from a 1990's HD truck:
https://www.amazon.com/dp/B001KQF6A2/
Amazon had one on sale for $93.00 shipped, so the Doorman unit had the right price for the budget.
Had to add my own grade 8 x 3/8-inch x 1-1/4 bolt at the steering box joint.
The picture of the parts above, shows a bolt without the metal angle which works for the upper connection at the steering column. The hardware came with the metal angle brazed onto the upper bolt head, (not as pictured). You'll need a lower bolt to install this, because the rag joint bolt might not work.
It installed easy, no cutting required.
If you lift your rig more than 2-1/2-inches, you might want the Borgeson unit, so you can adjust for body or added spring lift, when cutting the insert shaft down.
You should cut the shaft down so the column does not force the steering column into your chest during a front end collision, when required. It is supposed to collapse, not be installed maxxed out in either direction.
Get professional advice, before you mod this column, if you are not sure.
My repair for the lower bearing included machining a Delrin bushing to the steering column. The plastic race and clip was replaced. The Delrin is 1/2 inch thick and allows several screws to hold everything together.
Next up is the drag link ends:
https://www.amazon.com/gp/product/B001NZW4FU/
https://www.amazon.com/gp/product/B001NZW4K0/
These are in the cart and will be added next time to this thread.
The springs, hangers, box, shaft are all installed.
The TBI is getting over-bored next week.
Then the new built L31 SBC will go in.
It's raining and cold here. We had snow flurries this afternoon.
Will post more pics here, as the build goes.
From This:
To This:
As an Amazon Associate we earn from qualifying purchases.
