Which aftermarket LED headlights?
shanegtr
Perth, Australia
Shane
R2500 Suburban
Max has a set of Bangin Headlights and they work quite well as they are projector lights.
They have the glass lense and that was what Max was after for the set in his '49 truck.
He just told me to talk to George.
George may also do a group buy as he is a small business that builds these out of his garage in Australia.
They look correct and shine bright on the road.
I will be putting these into all of the classic rides when it is time to do so.
I'll give another vote for Bangin Headlights. I've had a talk with George a couple of times to try and get him to make the 89 quad lights, but no luck on that one yet. At the moment its just the more common 7" and 5.75" rounds and 4x6" rectangle lights he makes.
dec322
Indiana
Scottsdale K10
I just ordered the Gen2 from RMS. Hector responded quickly to my website inquiry and I’m looking forward to refreshing the headlights of my 84 k10.
75 Chevy SWB 4x4
NE Oregon
Doug
K10 4x4
I just installed these nice and bright LED headlights on my 72 Monte Carlo. They look exactly like my Harley headlight, except for the halo ring.
Ok, now we are going to require that you post a thread for your Monte in the Other Vehicles section! I love the '70-'72 Monte Carlo! And the a$$ end of the '73 too :rofl:
Dadoo
Minnesota
Jon
As an Amazon Associate we earn from qualifying purchases.
YakkoWarner
Central Texas
Wolf
R2500 Suburban
Did you make any changes to your wiring too? I've seen a few that recommend a headlight wiring harness that taps directly into your battery for 12V power and the original switch triggers a relay in the new harness.
I bought a kit like that for my British car project because they believed in hot-switching everything through the panel, and the aftermarket switches available today aren't really that robust anymore.
With LED lights the current draw should be less than originals, so I would think a kit like that isn't really necessary unless your wiring is a bit sketchy to begin with. I may use the kit anyway since I already have it, but I am always keeping an eye out for LED replacement headlights that look correct. I want ones that aren't "60000% brighter" than traditional lights - I don't want to be the person blinding everyone else. I just want correct, safe lighting with minimal current drain.
xm20k
Girard, Ohio
I went full LED nothing needs spliced or modified they all plug and play into the stock sockets.
Headlights
Front signals (they sell a yellow lense version as well)
Markers (they sell a red one for anyone that has the rear markers)
Tails (you can switch the sequential turn signal off, so they act like stock just on off, brake lights are not sequential)
Flasher X2
Guage bulbs (believe they fit stock cluster but I'm using them in Auto meter gauges)
YakkoWarner
Central Texas
Wolf
R2500 Suburban
Headlights
Flasher X2
Do you have the spec on (or are you equipped to test) the current draw of those LED headlights? They look pretty good and I like the glass lens as opposed to plastic, but Summit doesn't list the actual current draw on them.
texdave
Houston, Texas
tex
C25 Suburban
I'm a huge fan of the Holley Retrobright LED headlights. You can get them in a warm or cool white color. I've had both and they both deliver a crisp cutoff line and a great fill in front of you. Yes, they're very expensive but it's simple to install and it levels up your night vision to any new car's.
Camar068
10 yrs Air Force
I did, I used the LMC kit. Less than 6 months later one of the relays crapped out. Amazon for the same type and has been good since.
xm20k
Girard, Ohio
Don't have any specs as far as what they draw and I couldn't test them as I think someone needed my multimeter more than I did as it seems to have walked off.
I never loan out meters anymore,if they don't already have one,they don't know how to use one,I get it back with a blown fuse, in the on position and the battery dead.
xm20k
Girard, Ohio
Wasn't loaned out think it was grabbed out my box and walked off and out the shop. :mad:
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Headlights
Flasher X2
I second the Summit racing LEDs. I have them in a couple of vehicles now and really like them.
Tahner45
