FireTruck1984
Michigan
1984 and 1984
Thanks! I changed my name a couple years ago thinking I'd give the YouTuber thing a try but video editing is the bane of my existence lol. Might give it another shot with the TCI Suspension install. Or if nothing else, I'll just use our AMD footage
I saw your new tool box being delivered to AMD .. 30 year mortgage on that thing?
legopnuematic
Licensed Junk Dealer
MO
Spencer
Got the 14b sf project buttoned up and out of my shop (for friends 75 k5), new bearings, motive 3.73’s, Yukon Posi, B&M girdle cover, home brew rear disc brake setup.
Started doing some figuring for the 76’s new exhaust, my plan is custom sidepipes, which they may be somewhat unconventional, but doing it this way will allow me to still have an H pipe and not do the normal snake of piping to hookup regular side pipes. This is just mocking up with stuff I had lying around and 3d printed mandrel bends for fit up. The final product will be all stainless. Also got a Budge indoor cover for the 76 and 79, Amazon had them for a good price and jumped on them. Hopefully help with dust mitigation when I start doing more block sanding.
Yeah but I got a fixed APR :rofl:
AZ Highlander
Prescott AZ
Frank
K15 (aka V1500)
350 (5.7L)
Replaced the speedo cable. PO just cut it at the transfer case.
It is jumpy and loudly clicking.
From what I’ve read, it needs to be lubed?
WFO
Texas Panhandle
If lube doesn't work, the cable might be frayed.
New cables aren't very expensive.
AZ Highlander
Prescott AZ
Frank
K15 (aka V1500)
350 (5.7L)
thanks Dan. Yes, this one is brand new.
Any particular type of recommendations for lube for the speedo cable?
Silicone spray, ptfe "dry" bicycle chain lube, or other?
Moderator
Dry graphite powder. It's the only thing I've ever had good luck with.
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
Back in the day.......WAY back.....we used sylglide(SP) in a plastic tube, almost like vaseline. Pull the cable out, clean it and start about 6 inches from the speedo head end and lightly coat it all the way down to the other square end.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Such as this stuff?
Moderator
They still make the stuff, Napa has their own branded stuff. I primarily use it for the contact points on brake pads. But it works great for a whole slew of other uses too.
Did it last a long time for speedo cable lube? Seems to me like anything that let's dirt and debris stick into it will just gum up a speedo cable later on.
hauto85
