legopnuematic
Licensed Junk Dealer
MO
Spencer
Wouldn't hurt to look into a new steering box
legopnuematic
MO
Spencer
@Ontheboulder
The first post is covering rebuilding the box, if needed/desired, then follow the preload and over center adjustments. It will properly tighten up your old box.
WFarm
Central Virginia
K5 Blazer
I installed the Borgeson 800133 box last summer, along with a Borgeson steering shaft with U-Joints. Very happy with them, tracks straight and very little wandering.
WFarm
Central Virginia
K5 Blazer
Pretty much have things ready to install the serpentine belt components when it gets here tomorrow. USPS gave the kit an all-expense paid tour of the US East coast for some reason.
Marine Corps Moderator
Got some powder coating done today. Also got my buddies swing shackles, and sway bar/ U bolt mounts done for his 80.
Burkee1483
When did we get ice cream!?
bealeton virginia
mike
Did front to back LED bulbs and added the 2 led relays? in the fuse block today. Ordered new tail light buckets cause I don’t like how brittle these OG ones are. Also ordered tail light gaskets and new front side markers to replace the stock ones that are brittle.
Didn’t do much. Wife was sick and daughter had wisdom teeth pulled yesterday so I split early to grab em meds and cold things lol
On the hunt for a OEM hydraulic setup for the clutch. Just brain storming future changes
xm20k
Girard, Ohio
Ordered a set of these fender filler panels hopefully they help keep a bunch of road debris out of the new front fenders, since I'm not running fender wells.
Moderator
That will be interesting to know. I ran without fender wells on my C10 for a couple months and never noticed any buildup inside the fenders. But like I said, it was just a short amount of time and that's something I never even thought to pay attention to.
Burkee1483
bealeton virginia
mike
Now only if they would do the lower firewall panels using the existing fender mounts lol
Burkee1483
bealeton virginia
mike
Luckily the bottom of my fenders are self relieving aka rusted so everything falls out of em lol
Why aren't you running fender wells? Those will keep out some of the road junk, not all of it, they don't fit flush.
xm20k
Girard, Ohio
The fenders on it now are full of dirt and junk probably why they have a ton of filler in the lower sections that's now breaking up and starting to fall out.
xm20k
Girard, Ohio
I would have to cut the rear half of them out.
duncan_schawalder
