Soundmound
Aiken, SC
Dave
Scottsdale
They didn't use exhaust manifold gaskets when new. Rumor is they were more prone to crack exhaust manifolds when they had gaskets.
That's what I heard. I guess the silver lining being that after 41 years the heads and manifolds are still pretty true since it was a minor leak were a bolt was missing on the passenger side.
xm20k
Girard, Ohio
The bs with the alternator continues. I hate this bastard! It's even farther off now with the bottom bracket and spacer. The top bracket is got from summit was not even close to fitting. So I'm gonna go back and make it work with the other bracket because it closer.
Seems you might have a combo of short and long water pump brackets.
@82sbshortbed This may be what you need.
Marine Corps Moderator
Brother I probably have all the stock brackets...let me know if you want me to look from them. I might even be talked into powder coating them...
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
Relocate the bung. Plug and weld in another in different spot maybe?
This ^ That bung looks to be right in the middle of the merge in the collector it should sit farther back to get a good read on all of the output not just the closest one or two. Put a new bung in the top or bottom of the pipe (which ever has the best clearance) behind the collector flange about 12" or less of the collector.
^^^ I was going to say the same thing yesterday,but then I saw the Pic of the engine installed? What gives?
It could be worse, lol. In the 90's, there were cheap headers available for the 3rd gen F-body that had the O2 bung in the #5 primary tube.
So everything appeared fine, but once I actually had it in the truck bolted in entirely (motor mounts, bellhousing, etc) sitting where it would sit, then I saw the bung.
I'm either gonna take it off and have it professionally relocated as stated by @xm20k or notch the frame a little bit and put a 90 degree bung adapter on it. Which I'm not too keen on because then i feel like it's not technically getting direct exhaust reading as it normally would. . .
It's not that hard, screw a plug in the header weld a bung in the down pipe. The O2 sensor won't know the difference especially if you go 3 wire.
Sad Sack
Nebraska
Goober
C15
Yup, research "saddle bung" - $7 - $10.
Just some options
Tank6x2
You’re Awesome Know That!
Lifetime Supporting Member
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
trivia question for today is...
what are the original center caps of the 1988-1991 Burbs made of?
I have a 1991 GMC Burb 4x4 that needs one like this pic..
I couldn’t remember if I tried
Tank6x2
Kurt
C30
Started planning out my new rear bumper , I am not liking the one that is on it now and I dont like any others out there so I thought I'd try and make one that I did like . I am not 100% sure this is what I will be going with but it's a start .
Put some washout holes in the bottom of er
Tank6x2
Kurt
C30
Install all the new steering linkages, used antiseize under the caps, installed the frame to cross member supports, cleaned up and painted the last dust shield before reinstalling the motivator.
Tank6x2
Kurt
C30
Pic drop to correlate
82sbshortbed
Why like that?
SE Texas
Doug
1500 shortbed, 1500 longbed
mxer147
Colorado
Jack
k20
Painted grill, head light buckets, and interior trim pieces; most of you won’t like the white but my truck my way, no pics too much going on Saturday. Also added a coat of white to the door bottom two tone. Gonna try to get moving on this again to at least seal it up for winter so I don’t need the tarp.
jw23655
