Unknown Chevy Transmission Shifting problem
mrnapolean1
'87
R10
4.3 V6
I have a 1987 Chevy R10 pickup andI have noclue what Transmission is in it.
Sources tell me that this truck had several options for transmissions.
1. 700 R4
2. TH400
3. TH350
4. M38 Metric
Its not a 700 R4 because the truck doesn't have overdrive. It shifts 3 times.
I have never heard of the M38 Metric.
The problem that I have is it seems to shift at very high RPMs but it will shift.
Do you think a clogged filter would be causing this?
MadOgre
NA
NA
NA
NA
NA
Post some pics
ScottyB
Whatcom County, Washington
Scott
phantom
2 squirrels
1. 700 R4
2. TH400
3. TH350
4. M38 Metric
If it shifts 3 times it has 4 speeds. It starts in first and doesn't shift there, or am I missing something?
MadOgre
NA
NA
NA
NA
NA
No that's right 3 shifts = 4 gears
mrnapolean1
'87
R10
4.3 V6
It shifts fine but it shifts at what seems like very high RPMs.
I was told it can be a vacuum leak.
MadOgre
NA
NA
NA
NA
NA
Depends what transmission you have
77rig
