T-converter and flex plate separation noise?
78C10BigTen
pennsylvannia
C10 BIG TEN
That's exactly what happened to mine!!! I'm betting those rear ends are a whole bunch cheaper than when I had to buy one. Most of those trucks were still on the road at that point.
It blew a spider?? I cant find a 12 bolt posi to save my life!
Big Chip
Michigan
Kevin
C35
Yes but I was told it was because the pinion bearing failed. I remember it costing a lot of money when I got it replaced. For some reason it was a better option than replacing the ring and pinion. That was in 1990 though so I don't remember all the figures.
Moderator
Them thars teef!
In the past, I've put new spider gear sets into 10 bolts that have blown them out. Some ring gears were chipped, but they weren't in the contact patch so it still worked fine when put back together. Soccer mom's killed 10 bolts on snow and ice all the time. Should be able to do the same with your 12 bolt if absolutely needed.
78C10BigTen
pennsylvannia
C10 BIG TEN
Them thars teef!
Im looking at popping in a 10 bolt open right now for cheap
78C10BigTen
pennsylvannia
C10 BIG TEN
Update... im goin to get a 10 bolt open and drive shaft for $165 tomorrow morning. So itll be getting a 10 bolt and later on the guts will be getting upgraded to an 8.6 posi with 30 spline axles.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Good choice. Just pull the axles out of the 12 bolt and throw the rest away
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I still have questions on the gut swap... is that a good price?
Use a carrier from a GMT400 10 bolt and conversion bearings and your good to go and the axles from your 12 bolt
78C10BigTen
pennsylvannia
C10 BIG TEN
How do i know if the carrier from a gmt 400 is 30 spline. Can i use the carrier from one thats a 3.73 and swap rings?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
How do i know if the carrier from a gmt 400 is 30 spline and does it need to be from a 10 bolt or just any rear from a gmt400? Can i use the carrier from one thats a 3.73 and swap rings?
Has to be a 10 bolt. 3.08-4.10 are the same carrier. They are all 30 spline in the GMT400 10 bolt
78C10BigTen
pennsylvannia
C10 BIG TEN
Where do i look in your thread for the part numbers
hauto85
