400sb flex plate torque spec
mjck5
wisconsin
mark
1986 k5 blazer
k5
hey everyone,
i had to replace my flex plate in my k5 with a 400sb and a 700r4 tranny, i cant find any reliable torque specs anywhere, anyone know what the flex plate and torque converter should be torqued to? and what size of gap should there be between flex plate and torque converter?
xm20k
Girard, Ohio
Flex plate bolts 65 torque converter 35 both with thread locker.
xm20k
Girard, Ohio
Almost forgot should be 1/8" between converter and flex plate with the converter fully seated in the front of the trans if there is say 3/16" you'll need to add a washer or shim to make up the 1/16" at each bolt so you only pull the converter forward (away from the trans) an 1/8" to contact the flex plate.
duncan_schawalder
