Speaker mounting
30backs
Middle Ga
Scott
So I am doing a audio upgrade in my truck new pioneer cd play and new pioneer speakers. I picked up some 6x9's to do cab corner mounts and I also picked up some 5.25's any ideas on how to mount these anywhere around the dash area in my 88 r20 cclb?
The space between the steel frame and the underside of the dash pad is extremely limited. Also real tight in the horizontal plane (esp in the A pillar and windshield directions). The 3 1/2" speaker that came with the truck is about the limit in that area.
Some people try to "hang" aftermarket speakers under the dash frame -it's not an easy process.
Ever considered mounting the 5.25's in the door panels?
30backs
Middle Ga
Scott
I thought about it but I was worried about water damaging speakers.
Xredman002
Seattle
Jeff
Apache, custom camper, gmc 3/4, jimmy
283, 283, 350, 350
I am mounting speakers in the door but wondering how to get the speaker wire there
Do you have power windows/door locks? If so, just fish the leads for the speakers the same way as that wiring. Through the rubber plug, across the A pillar and then through the "accordion" to the door cavity.
If not, you might think about this system:
Jamb TAC Wireless Connectors
No more running wires through door jambs when installing your stereo system, power windows, or power locks! Mounts anywhere on door jamb.
Good idea but if the door is open, the speaker is disconnected - if that matters to you.
That's what the Burbs have on the barn doors for the contacts for PDL and Defrost.
sallyjeank10
