Swims350
- Jul 30, 2010
- Logan WV
- Chris
- K10
- none
Ok never built one, pretty familar with engines. I had questions though... mostly on doing one on the cheap.
Do you have to get machine work done? other then making clearance for the rods near the oil pan rails?
Do you have to clearance them?
Do you have to have an oil pan that's clearanced too?
Can you use stock 350 rods?
If so then how? bearings spacers or something I thought I heard of?
If you buy a stroker crank like eagle or scat, do they use stock 350 rods or 400 ones?
I know you have to get a flywheel/flexplate and balancer from a 400 and have it all balanced.
Also you must get special pistons right? no stockers?
