- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
the advertised duration is 302 duration at .050 is 246 and the valve lift at .050 is .50" lift not that low for a flat tappet cam i know there is bigger but wouldnt waist the money on any bigger id go roller if i went any bigger
So what you're saying, is .500 lift? Most cams are given lift specs in .000. I didn't think it was that high because I used to run a 305 duration, .510 cam and when I first built that motor, the OEM valve covers were just sitting on the heads with 2 bolts started to keep oil from running everywhere when I primed it, then when I started it up, I got dents in the valve covers from the lift being to high for OEM covers and had to drop everything and go buy tall covers before I could continue working on it.
