Lifting my 85, what do you think?
Joshuacurtis
New Hampshire
Joshua
I am looking to install a 2 inch suspension lift in my 85 k10. What do you recommend for tire size. If you have pictures post them. I'm thinking maybe 33s with 16inch wheels. Not sure if 35s will fit.
Currently my truck is stock height with 31x10.50 15s.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
It's all about what you would want to see on your truck. If it were me, I'd do stock rallies on 33s.
Joshuacurtis
New Hampshire
Joshua
I like when my tires fill the wheel well and I would rather they didn't rub, but its not the end of the world.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
33's will fit up a good portion of the wheel wells. Shouldn't have much issue on roads, but off them you'll probably have a bit of rubbing.
35's will rub everywhere and anywhere with only a 2" lift unless you do major cutting to the fenders.. i.e. like cutting a good solid 2-3" strip the whole way around them.
I'd say that with only the 2" lift you're going with, stick with the 31's for now and see how much room you've got everywhere when its all twisted up and on a day to day basis. Then you can determine if you can only fit 32's or step up further to the 33's.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Found an old photo of my truck to help with your decision:
That was at stock height with 32x11.50 R15 Yokohama Geolander AT/S tires on a set of 15"x10" Slot Mags with 4" Backspacing. Fenders have been slightly trimmed at the front and rear of wheel well.
Previously had a set of 33" coopers or dunlops on the same stock height, but they definitely rubbed at full turn and when driving through dips.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
No way man 8" lift and 24" tires is the only way to go.......
Missing the 20"x12" wheels for your 24" tires.
Arkansas
Cody
2" lift will clear 33" tires easily. For reference, here is a pic of my truck at stock height with 32x11.50x15 trailblazer a/t tires. Fenders were never trimmed and no rubbing issues.
Joshuacurtis
New Hampshire
Joshua
Love the Look I think a 2inch lift and 33x12.50 15s will look good.
jingle1
