75gmck25
- Oct 13, 2016
- Northern Virginia
- Bruce
- K25 Camper Special TH350 NP203
Start out with determining a rough budget. Then price out a 350 or 383 roller block, and either Vortec iron or aftermarket aluminum heads. This should be your starting point for upgrading.
- A Vortec or aftermarket aluminum head will outperform any camel hump or other gee-whiz head from the 60’s. Your goal is a good flowing head and about 9.5 compression (to run on regular). Your stock smog-era heads are really horrible.
- with a roller cam you won’t need to worry about wiped lobes and can use more aggressive ramps without breaking anything. The only downside is that it costs more up front. For best gas mileage you would use around 195 or 200 duration, but up to about [email protected] will give you more power without screwing up gas mileage too much.
- by mid 80’s GM had mostly solved the bowl leak issue with the Quadrajet, but throttle shaft wear is still something to look for. Don’t have sticker shock when you find out how much a quality rebuild will cost.
- switching out your 3.73 gears is not worth it when you have a 700R4 already. It’s actually a very desirable ratio for both power and gas mileage.
My GM 350 crate has the upgrades above, along with headers and full duals, but I have 4.10 gears and a TH350, and full-time 4WD NP203. My highway gas mileage is about 10.5 MPG if I keep it down to 65-70 mph. When I looked at old car magazine reviews of these trucks I found that even then they only got 14 MPG when driven on the road.
