1978 Chevy 305 starts once but dies right away
Ok, so there's something to look at. Timing. Because you changed that during the install.
It's possible that your timing could be way off for your particular application, if it does indeed have an unknown cam swapped in. There's also things like incorrect timing tab installed or slipping outer balancer that could be potential issues. Those ones can really cause you some trouble.
I wonder where in the grand scheme of things when he set the valves?And if they are all correct?also wonder when the egr was removed ( bad idea) and if it is sealed? or a giant vacuum leak,external or from exhaust passage to intake. Hmm wonder if that cam chop at idle is 2 crossed plug wires a tight intake valve,a vacuum leak and retarded timing.
xm20k
Girard, Ohio
I'd take a deep breath and start from the beginning and go back over everything. One step at a time.
Verify firing order is correct
1-8-4-3-6-5-7-2​
add 8-10 degrees of advance (about 15 initial)
set the idle air back to 1 1/2 turns out
turn the idle screw out till the throttle lever stops moving turn it in 2 full turns
try and fire it
With these settings it should fire and idle high and stay running if it will not start and stay running at this point, I'd look at fuel pump, ignition parts, distributor is in correctly at TDC, balancer hasn't slipped, massive vacuum leak etc.
If it does fire and stay running even with a high idle this is your starting point for tunning you can't tune something that won't run for more than 3-5 secs at a time.
set total timing from here back and forth between setting total and turning the idle down till it idles and total is around 34-36 degrees initial will fall where it falls.
then adjust idle air with a vacuum gage
75gmck25
Northern Virginia
Bruce
I reread one of your earlier posts and found where you said you had a massive backfire. Since that time have you rechecked your PCV valve to make sure it still works correctly at idle?
I had a backfire once on my truck and it blew the PCV valve out of the valve cover. I checked all kinds of other things, and then finally noticed the PCV hose laying on the valve cover. That hose being off created a massive vacuum leak that should not be there at idle. I wasted a lot of time to identify a really easy fix.
x_jalbert
quebec
xavier
So, I took off the carburetor and opened it.
It was filled with garbage.
Cleaned it out put it back in and truck started right up.
I just want to point something out.
I’m really not trying to be mean and obnoxious, but if you guys respond to my problem by saying check the firing order and I reply to you guys that I checked it, there really isn’t any reason for you guys to keep telling me to check. If you can’t trust what the original poster says when he replies to your suggestions, it’s not helping to keep pointing the same thing.
It’s running on all 8. But now it dies in gear when cold. When hot it stays running but not rlly a consistent in gear rpm. Park idle is 1000rpm and drive idle is 600-700-800rpm
Thank you guys, and like I said, I’m really not wanting to be snarky, mean or come across the wrong way when I say to trust what the original poster says.
Here are pictures of the engine bay
xm20k
Girard, Ohio
It’s running on all 8. But now it dies in gear so what’s next.
The number of times we've been thru this and after pages of trouble shooting find out it was some dumb simple thing we suggested 5 pages back is not a new situation we can't just look over your shoulder thru the internet. :cool:Timing/wiring tends to be the most common issue followed by fuel supply issues. These engines are stupid simple for the most part.
Go thru and set the total timing and then set air idle with your vacuum gauge now that it will idle.
Sad Sack
Nebraska
Goober
C15
So many unknowns. Having an altered engine with a supposed different camshaft with unknown specs cam can be trouble. Get a degree wheel and dial indicator to get lift measurements. Sounds like a loaded idle setting is not good. Does the cam need a higher stall TC?
Understand the engine - understand its needs.
Moderator
I still think it would be wise to play with the timing and see if it likes another setting better.
Sad Sack
Nebraska
Goober
C15
What is the fuel pressure at the carb in park/idle?
You stated rebuilt carb but full of junk, this muddies the waters a bit...
I didn't see a single post where you said you double checked anything we mentioned,just its fine,like you couldn't have a mistake. You have no idea,the number is unbelievable how many people say yea the wires are on right,but then they check or a friend checks or I check and they are wrong. You are asking us for help amuse us check the things we ask you to check,tell us yea I checked that's not it. You've rubbed more than one of us the wrong way with this deal. Telling @bucket " good for you I guess" when he was just letting you know typically.header install doesn't require major tuning. And it didn't,adjustment isn't/wasnt the problem. I still want to know how the carburetor didn't get full of garbage and plug the idle circuit until the minute you fired it up after the header install. This whole thing hasn't made any sense.
x_jalbert
quebec
xavier
I didn't see a single post where you said you double checked anything we mentioned,just its fine,like you couldn't have a mistake. You have no idea the number is unbelievable how many people say yea the wires are on right,but then they checknor a friend checks or I check and they are wrong. You are asking is for help amuse us check the things we ask you to check,tell us yea I checked everything that's not it. You've rubbed more than one of us the wrong way with this deal. Telling @bucket " good for you I guess" when he was just letting you know typically.header install doesn't require major tuning. And it didn't. I still want to know how the carburetor didn't get full of garbage and plug the idle circuit until the minute you fired it up after the header install. This whole thing hasn't made any sense.
I rebuilt the carb 2 weeks prior to installing the headers and only burned 1 tank.
Maybe the truck ran somewhat ok but the fuel supply was low but it was still fine since the stock manifold choked the engine so much that the mix was ok.
After putting on the headers and letting the engine breathe, it’s probably what made it noticeable after.
And I’m sorry if I didn’t mention but I did actually check the firing order one more time after you guys told me to.
Just finished off a drive, and the drive idle has stabilized to 800rpm. Engine not as sluggish as before although my secondaries don’t seem to be opening in 3rd gear. My friend who knows how to time engine is gonna help me to change the timing like you guys said.
Although now my tranny is leaking oil kinda bad there’s oil all the way to the transfer case. It’s coming from where the dipstick, oil cooler lines and the kickdown cable booth go. I recently changed the kickdown cable because my booth was cracked I just hope it’s not leaking from there again, I don’t want to have to remove my headers again.
x_jalbert
quebec
xavier
I don’t have a fuel pressure gauge. My tank has debris in, when I remove the inlet at the carb and crank the engine to pump the gas into a plastic bottle, there’s a good amount of junk.
I’m going to drive it and burn my tank up to be able to drop it (I just filled it up two days ago and I don’t have any gas canister that can hold the full amount and I don’t feel like spending 60$ just to siphon my tank)
All my fuel lines are steel so I can’t put another fuel filter. What tool do you guys recommend to cut a piece of steel fuel lines to be able to put a filter in between? I only have power tools here and I rlly don’t feel like blowing myself up XD
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
If you can figure out where your closest auto parts store is ...go there and ask for a tubing cutter.
xm20k
Girard, Ohio
In line filter and a piece of hose and a few hose clamps should be able to take the rubber off at the hard line back by the tank and put an inline filter there and a section of hose to connect back to the hard line. If it has dual tanks put it in the hose between the hard line and valve.
Moderator
Are your mixture screws still 6 turns out to keep it running when shifted into gear?
If you could adjust the timing to 6° advanced by yourself, you don't need to wait on someone else to help you mess with it some more. Like I said before, there's always the chance that your timing marks are off by a little or a lot. Timing that's too far retarded can cause rough running, lower idle, hard starts and poor power. You can start by just advancing the timing for highest idle and see how it runs then. If you get pinging or if the starter struggles on a hot restart, back the timing off a few degrees and try again. Also adjust your mixture screws for highest vaccum... not whether or not it keeps the engine from stalling when dropped into gear.
Turn the timing up to highest vacuum,then turn it back 1"hg
doo-daa
