1978 Chevy 305 starts once but dies right away
I've seen lots of guys say the wiring order was fine then find 2 wires crossed. I have no Idea how you got the manifolds off and the headers on without pulling the plug wires and at.least bumping into 1 or more plugs getting the manifolds out and the headers back in. The reason I lean towards the things I've already said is that it is about 100x more likely considering you say it ran fine until you installed the headers,then it didn't run right and you had to play with mixture.It would be quite a coincidence that while you had the manifolds off.the fuel pump or carburetor suddenly went bad. I'd check firing order again,I'd look for vacuum leaks,cracked plugs and feel for cold cylinders 1 or 2 cold cylinders is going to rule out fuel as a problem,and its an easy check. Anything you did the same day as the headers should be double checked,like if you changed timing at the same time,maybe that's your problem. The backfire through the carb is a HUGE clue, almost always ignition,and I suspect 2 wires crossed or timing way off.
Moderator
I didn’t mean it as a snarky reply but you said you never had to change the mixture to keep and engine running when I said earlier that it was the only fix for me. It just felt like you thought I did it for no reason.
I really didn’t mean it in a bad way English is not my first language.
It's just hard sometimes when reading something online... it's much easier to judge the situation when face to face.
What I meant was that 6 turns out isn't right and while the issue popped up after you installed the headers, the issue is most likely from something else that happened at the same time.
Vacuum leak, crossed wires, improper timing, etc.
x_jalbert
quebec
xavier
I installed the headers 2 weeks ago.
What I mean by I haven’t touched anything is yesterday truck ran and this morning it wouldn’t. That’s what I mean by i didn’t touch anything.
x_jalbert
quebec
xavier
I have 15mm hg at the brake booster port. Seems low but I saw online that a cam can lower idle vacuum so I don’t know what to think. The needle is not stuttering much, just a tad bit. Pretty much a constant 15 vacuum.
What do you guys think, still low even if I have a cam ?
After you changed the headers you immediately had a problem,had to adjust mixture had a giant backfire through the carb, truck ran good before,then had no power. You need to go back over what you did 2 weeks ago and you probably should check your plugs. If you've been running on 6,which I suspect you have, and now you've fouled the 6 that were working by richening up the mixture so much. Just my guess
Timing off will lower the vacuum,a cam will lower the vacuum, a vacuum leak will lower the vacuum, too low of idle will lower the vacuum and 15 at this point its too early to say what's going on there,that maybe all you ever get a big enough cam the best a person might get might be 8in. Right now check your basics. Same things I've told you twice to check. You think it won't start because of a fuel pump or carburetor. I doubt that's your problem. Easy enough to check dump 2 Tablespoons of fuel down the primary bores of the carburetor 1TBS per side step on the pedal let off the pedal ,try to start it give it a little throttle if its not starting. If it starts and then dies its a fuel problem.
The Right side of Washington
I was having troubles before with my truck I was just listing everything I did so far with my truck. Not the stuff I replaced related to this very issue right now.
My truck ran rlly great before I put on long tube headers but I had an manifold leak so I figured I’d put the headers right away.
Then it wouldn’t start so that’s why I changed everything in the distributor cuz that’s what it looked like inside.
I haven’t disconnected at the pump and verified the flow today. I did that before changing my headers and it was fine. (I had trouble to make it start at that point and I had spark so I checked fuel, turned out to be the choke being reinstalled the wrong way)
Understood. But what I meant was fuel pump could be giving up on you.
I agree with the other guys, headers and then not running right or starting at all, suddenly, is a coincidence.
Your old distributor and coil don’t look horrible. FWIW.
There are many things to look at. Timing, fuel pump, maybe new coil or ignition module (could be bad new parts).
The bogging running and backfire suggests something spark or ignition related possible.
All suggestions.
Another suggestion or some knowledge for you. This forum, and some of the guys responding to you are imo, probably the best or most experienced or resourceful folks when it comes to Chevy engines, and other things too. Don’t discount what they say as any sort of bad advice. The brain power and helpfulness collectively from many members here is second to none.
Keep at it. And when you learn what the problem is and share it, it’s just helping the next guy.
75gmck25
Northern Virginia
Bruce
Do you still have the spring that goes with that filter? It is possible to put the spring in on the wrong end, which will affect fuel flow.
With a cold engine you should first pump the accelerator a few times, relatively slowly. This will make the accelerator pump shoot in some fuel, and also allow the choke to set in the cold (choked) position.
Then take your foot completely off the accelerator pedal. When you then turn the engine over for a few seconds it should fire, and in most cases will start up and idle unless the weather is very cold.
If the engine is really cold, or has been sitting so long that the float bowl is dry (so you need the fuel pump to refill the carb), you should try the same accelerator pedal pumps and engine turn over again. The second time around you definitely have fuel in the carb, so the accelerator pump should give it a good shot. Once it fires and runs, continue to keep your foot off the accelerator until the idle evens out. It’s still running cold and lean, so too much air right away will make it die out.
6 degrees BTDC base timing should work, but acceleration will be wimpy. 12 degrees will work much better with regular gas, and should give it a little more pep.
Quadrajet mixture screws should be fine with a starting point of about 2-3 turns out, and then tune further for best rpm or best vacuum. I think mine work fine at about 2 1/2 or 3, and playing with them further does not change rpm much.
As already suggested, look carefully at everything you removed or replaced when doing headers, and make sure you got it on correctly. It’s very easy to make a simple mistake.
x_jalbert
quebec
xavier
Giant backfire thru carb happened on the 30th of October after holding it wide open for 5 second.
I changed the headers around the 15th of October. During those two weeks truck was drive able and start able.
Yesterday I pulled my plugs and they were dry. All sparks plugs have fire I verified it after changing the headers because I had issues. That’s also when I changed all the parts in the distributor.
I’m sorry in my original post I made it seem like all the parts I changed were to fix the problem said in the post but it wasn’t. It’s just everything I’ve done to the truck since I have it. I’m sorry for the confusion. Truck has been running lean even after 6turns out
x_jalbert
quebec
xavier
Timing off will lower the vacuum,a cam will lower the vacuum, a caccum leak will lower the vacuum, too low of idle will lower the vacuum and 15 at this point its too early to say what's going on there,that maybe all you ever get a bigger enough cam the best a person might get might be 8in. Right now check your basics. Same things I've told you twice to check. You think it won't start because of a fuel pump or carburetor. I doubt that's your problem. Easy enough to check dumpb2 Tablespoons if fuel down the primary bores of the carburetor 1TBS per side step on the pedal let off tge pedal ,try to start it give it a little throttle if its not starting. If it starts and then dies its a fuel problem.
I does start but dies right after after doing the weird manipulation mentioned in my first post. Which is why I’m suspecting fuel problem.
x_jalbert
quebec
xavier
All suggestions.
Yes, and I’m very grateful for the help you guys are giving me. I mentionned before but English isn’t my first language so if I come off as rude, it really isn’t my goal. I’m really just trying to rule out problems and if I ask questions back to your suggestions, it’s only so I can understand the problem more. I’m trying to understand and not just change parts until it works :)
x_jalbert
quebec
xavier
Yes I do still have the spring that’s goes with the filter and filter is installed properly (open end facing fuel inlet)
Weather is cold around here but my truck used to start better cold than hot to be honest. When cold, if I gave it one full throttle press, it would be borderline flooded. Starter didn’t even have to turn one revolution for the motor to start.
As for header install, the thing that also changed was I found out my distributor cap was loose so I fixed the timing at the same time ( and all the parts in the distributor). Beside fixing the timing, I had to remove plugs, spark, rebend new tranny cooler lines and that was it. All the egr system on my truck is removed so there’s not a whole lot of vacuum lines remaining. There’s the pcv, brake booster, choke, tranny, vacuum advance and that’s pretty much it. All the lines look good. I can take a picture when I go back this morning so you guys can tell if something is horribly wrong but all the lines are hooked up the same place they were when I got the truck‍♂️
I tried tuning my mixtures screw with vacuum, but my vacuum would stay at 15 so I just gave up and turned them out until it wouldn’t stall in gear.
Moderator
Ok, so there's something to look at. Timing. Because you changed that during the install.
It's possible that your timing could be way off for your particular application, if it does indeed have an unknown cam swapped in. There's also things like incorrect timing tab installed or slipping outer balancer that could be potential issues. Those ones can really cause you some trouble.
Trucks been running lean EVERY SINCE you put the headers on. There's a clue. I drove it it felt sluggish I held it wide open it Backfired,there's a clue. It quit running right AFTER you started messing with things. I've seen this TOO MANY times at work. The engine you guys installed started running bad. What did you do to it? Nothing. Okay we'll look at it. These aren't the plug wires we installed. Yea but that shouldn't keep it from running. It will if you got a couple crossed Yea but I double checked it. Hmm well you've got 5 and 7 crossed. My car died after you worked on it what did you do to it? Nothing. Towed in. You ran it out of gas . That engine you installed doesn't have any power. What did you do to it? Nothing. We'll have a look. How did the timing get off? I set it,but I did it right. Etc.etc.etc. go back with a friend that knows what they are doing and go over everything you've already done. My left thumb is sore and purple,maybe that's from when I hit it with the hammer days ago,not something new. Damn near evertime we had a customer concern,it was because the customer messed with things after the fact and they always say they didn't do anything or they didnt do anything wrong
Moderator
Trucks been running lean EVERY SINCE you put the headers on. There's a clue. I drove it it felt sluggish I held it wide open it Backfired,there's a clue. It quit running right AFTER you started messing with things. I've seen this TOO MANY times at work. The engine you guys installed started running bad. What did you do to it? Nothing. Okay we'll look at it. These aren't the plug wires we installed. Yea but that should keep it from running. It will if you got a couple crossed Yea but I double checked it. Hmm well you've got 5 and 7 crossed. My car died after you worked on it what did you do to it? Nothing. Towed in. You ran it out of gas . That engine you installed doesn't have any power. What did you do to it? Nothing. We'll have a look. How did the timing get off? I set it,but I did it right. Etc.etc.etc. go back with a friend that knows what they are doing and go over everything you've already done. My left thumb is sore and purple,maybe that's from when I hit it with the hammer days ago,not something new. Damn near evertime we had a customer concern,it was because the customer messed with things after the fact andvthey always say they didn't do anythingbor they didnt do anything wrong
Yeah, whenever someone was having an issue with their vehicle, a wise old man that I worked with would always ask them "Well where did you **** with it last".
doo-daa
