x_jalbert
- Oct 24, 2026
- quebec
- xavier
- k10
Hello everyone.
I just want to start by listing everything I’ve done to the truck before explaining my trouble.
Truck setup:
1978 Chevy k10 frame with a 1983 Chevy c10 cab/ body
Motor: small block 305 2 bolt
Carburetor: Rochester quadrajet
Tranny: th350
Transfer case: np203
gearing: 308
Tires: 33 inch
Stock height.
Previous owner says it has a cam on it but I don’t know for sure ( it does chop, when it starts…)
New parts:
- distributor cap
-distributor rotor
-hei module
-ignition coil
-spark plugs
-plug wires
-long tube headers
-new battery
Work done/ things verified:
-12v at bat terminal distributor
-timing set at 6degrees (vac advance disconnected)
-firing order is in order.
- carb has been rebuilt
- idle mixtures screws 6 turns out (had to do that to fix previous issue where it would die when put in gear)
-15mm hg vacuum at idle at the brake booster (before when it ran)
-valves have been set to 1/2 turn preload after zero lash
-choke system is properly installed (had troubles with it before and I fixed that)
Ok so here’s my problem.
Ever since I put on my long tube headers, truck been acting weird. It would die when put in gear. I turned my idle mixtures screw out 6 turns and set park idle to around 1000rpm. When I’d put it in gear, rpm would drop to 400-500-600rpm (my rpm gauge is cheap so that’s why I don’t have a precise number). In gear at idle it would sometimes die and sometimes not.
Yesterday I went for a drive with my truck and it felt really sluggish. I know I don’t have a setup to win drag races but still. So I decided to try it wide open throttle in a hill.
My rpm’s were pretty much staying the same and speed too. After 5-6 seconds, I heard a huge backfire through the intake. It was so loud I thought my engine launched a piston thru the block. But after letting off the pedal it stayed running.
So I kept on driving avoiding wot.
A couple kilometers after, I was following a car and he was braking to go in his driveway so I reduced my speed to 50kmh. When he turned and my lane was free I hit the gaz to climb back up to 90kmh. But the truck felt so sluggish I had my pedal at 80-90% and truck just wouldn’t climb in rpms or speed. After like a min I was at 90 again. I decided to park my truck and investigate the problems.
Came up with the conclusion that it’s probably a fuel related issue.
This morning I went and bought a new fuel filter. Old one was crusty (I’m going to show pictures) so I put the new one back in.
Truck doesn’t want to start.
Been cranking and priming and cranking and priming to no avail. Then one old timer comes up to my and gives me a trick.
10 second hold the pedal down
Wait 3 sec
Pump pedal halfway 3 times
Wait 3 sec
Hold the pedal halfway and crank it
And before you know it, it starts but dies right after. Kept on trying and nothing. Would only briefly start using this method.
So now I’m lost. Sorry for the long paragraph I just don’t feel like wasting anyone’s times asking me stuff I already changed/ checked.
Truck setup:
Tranny: th350
gearing: 308
Tires: 33 inch
Stock height.
New parts:
- distributor cap
-distributor rotor
-hei module
-ignition coil
-spark plugs
-plug wires
-long tube headers
-new battery
Wait 3 sec
Wait 3 sec
