1978 Chevy 305 starts once but dies right away
Turbo4whl
Downingtown, PA
Wayne
Jimmy
All my fuel lines are steel so I can’t put another fuel filter. What tool do you guys recommend to cut a piece of steel fuel lines to be able to put a filter in between? I only have power tools here and I rlly don’t feel like blowing myself up XD
Should be a rubber fuel hose from the fuel tube on the frame to the fuel pump. You could put an inline filter there.
3/8" inline filter with a check ball in the inlet.
You have stated you have a truck that has been modified.
To recap, you didn't understand my question about the bent up fuel filter. To be clear there, early carbs. use a shorter filter. If you are using an early carb and install the long filter it will look like your picture. Now I understand you opened it for inspection.
x_jalbert
quebec
xavier
Are your mixture screws still 6 turns out to keep it running when shifted into gear?
If you could adjust the timing to 6° advanced by yourself, you don't need to wait on someone else to help you mess with it some more. Like I said before, there's always the chance that your timing marks are off by a little or a lot. Timing that's too far retarded can cause rough running, lower idle, hard starts and poor power. You can start by just advancing the timing for highest idle and see how it runs then. If you get pinging or if the starter struggles on a hot restart, back the timing off a few degrees and try again. Also adjust your mixture screws for highest vaccum... not whether or not it keeps the engine from stalling when dropped into gear.
Yes I kept the screws at 6 turns out
When I took off the carb I put them at 3 turns hoping the problem was just fuel delivery, but no engine died when in gear. So I put them out at 6 out and it was ok.
Went for a drive yesterday and my engine is really missing some top end. Secondaries don’t seem to be opening. I’m guessing not enough fuel to create enough vacuum to pull them open.
Disclaimer:
I will play with the timing like you guys said and today I’m going to put an inline fuel filter and new fuel pump. I’m thinking of putting the filter before the pump so my new pump doesn’t have garbage going in it.
As for my idle mixtures screws, I’ll give it a shot with my vacuum gauge but last time i tried, vacuum wouldn’t really budge no matter what I did with the screws. Result might be different with new fuel pump.
NLD79K10
Netherlands
Lars
If you're putting in a new pump, make sure to check the fuel pressure. Many new pumps tend to run at higher pressures than the factory spec and you may need to add a fuel pressure regulator to deal with that. Got to love modern day quality control...
doo-daa
