Quarter-half throttle stumble
82_k10
Louisiana
Amadia
350 sbc
I have a 1982 k10 350 sbc turbo 350 with a terrible half throttle stumble. It has a new relatively new edelbrock 1406 with a street fire distributor. Other than shorty headers the motor is bone stock.
I drove the truck for almost a year straight with a small half throttle stumble that I could never get rid of. At the time it was very easy to avoid but after a year of driving, the rear end blew and it sat for about a year until now. I’m getting around to trying and getting it back on the road and the stumble is now so bad it’s almost undrivable as it will start sputtering at 1/4 throttle and if I try to power through it it will almost die. Only way to avoid it is if I pretty much floor it every time I take off.
I’ve checked the timing 20 times tried every metering rod and step up spring combo and nothing has gotten rid of it or change the way it acts. Only thing that helps is putting the accelerator pump to max output. Which makes me think it’s a lean stumble.
Ever since I’ve had the truck the brake pedal has always “hissed” or whooshed as I press the brake, but stops when the brake is being held. Always thought it was normal. It never occurred to me that the internals of the brake booster could be leaking vacuum.
Recently I took every single vacuum line off and plugged them all. And the motor ran great almost no stumble at all. So I started hooking lines back up until I found which one was the culprit. Turns out it only seems to run better when the brake booster and pcv valve are both unhooked and plugged. If only one is plugged on either one it still has a stumble. However when taking the pcv valve out and plugging it, the motor will almost die as the idle drops so low.
So now I’m stumped. Is a loud whoosh when pressing the brake pedal down normal for a vacuum booster? Should a pcv valve be pulling that much vacuum? And are both of these things normal and it’s only running better because with a little less air flow from the 2 main vacuum ports causing it to run a little richer and get rid of that lean spot, but not fixing the root cause.
I have plenty of videos and pictures I can send to someone if they would like to help. (337)532-5750
Any help is appreciated! Thank you.
Where is the timing set? Ran good then parked a year,now runs like ass. Have you run all the year old gas out yet?
doo-daa
