- Feb 24, 2020
- Auburn, Georgia
- Zach
- Sierra 1500
I would find an aftermarket headunit you like. Unfortunately in these, you can't just swap in another OE, the security system won't allow it. Any OE headunit you pick up will be VIN locked to the vehicle it came out of, the dealer is the only one that can unlock/reprogram and these are old enough they may not be able to anymore or have a tech that knows how.I want to swap in an OEM radio (UB1), but I am wondering if it may be easier to just buy a new JVC since the bluetooth microphone and other stuff was already installed with the current JVC. I have no idea what they did or did not do to install the JVC. Did they replace everything? Or just install the head unit? I need to dig into that.
Get the harness through Crutchfield, they'll ask some questions about the options and have the harness you need and it'll be good quality. I've never had luck getting harnesses anywhere else. As long as the PO didn't butcher it and hardwire everything like it's 1970, you should be able to unplug what's there and plug in your new harness. Then the other end of the harness just wires to the radio wires.
