86 c10 lowering
86c10kid
McVeytown Pennsylvania
Clay
400 sbc
Hey I’m looking to lower my truck something like a 2/4 drop. Why all do I need or can you get some kind of kit? Also what is a good brand? Or could someone point me a forum I could read? Thanks!
bluex
Spartanburg SC
C15
Scott91370
Burleson, Tx
Scott
Sierra1500
As bluex said, the linked thread has a lot of good info.
In short,
Front - spindles, all day - every day. Retains original geometry and (mostly) alignment.
Rear - shackles.
In short,
Rear - shackles.
Same thing I was going to say but that's going to get him 2 or 3 in the front but only 2 in the rear. But it would be cheap and easy. I think @xm20k has some front lowering spindles for sale
xm20k
Girard, Ohio
About a 3.5-4hr drive from me. I have an entire CPP 4/6 kit with maybe 200 miles on the truck before changing up a lot of my build.
Springs, spindles with new Big Ten rotors and bearings, flip kit, notch kit. as well as a bunch of other C10 stuff.
Shoot me a message if interested and I'll make you up a complete list.
Sorry Rick didn't mean to quote you in that.
TrybalRage
Reading, PA
Dave
For that small of a drop, spindles in the front and drop shackles/hangers in the back. Springs would probably be cheaper, either drop springs or cutting coils, but then you're messing with your camber.
I used belltech spindles on mine, but I think any of the big brands would be fine. Can't make a recommendation on the shackles/hangers because I did a flip kit - but you don't want that as you'd be looking at more of a 5-6" drop in the rear.
Torrey
Tulsa
Torrey
LS
One thing to consider when using spindles is future front brake plans. Some will fit stock and some are designed for aftermarket brakes. Don’t pigeon hole yourself.
peats
Pennsylvania
john
k5 c10 k10 SSR doodlebug
406 360 6.2 5.3 171
Exactly what I have on my '81 c-10. 2" drop springs in the front, 2" shackles in the rear . and 2" spring mounts for the foreword end of the rear springs. My truck sits level. I fabricated Timbren bump stops that allows me to carry quite a load with no worries or sag. Keep a lookout for shackle to bed strip contact.I had to trim away the bed reinforcement ends to clear the shackle, no big deal. Parts are available at LMC and the Timbren took light fabrication.
Aj Farias
Adilson
Silverado 1500
What drop will i get with the flip kit? What about front what do you recommend?
Aj Farias
Adilson
Silverado 1500
I have a 84 c10 i want to lowering.
I just want the top of the tire to be flash with the fender edge. I dont want the tires inserted in to the fender box.
What are you guys recommend cheap, easy to do and i will try no to change a lot from original for alignment etc.
If you guys can help me with best rout to go and links with parts i have to buy i will appreciate.
Aj Farias
Adilson
Silverado 1500
Start your own thread. It gets confusing working on 2 different vehicles on the same thread.
wisco11
