383 Build
hirschdalechevy
norcal
rich
k-30
Another suggestion , have your machine shop check all your parts before putting your short block together. Eagle is made in china , (not saying it's bad) but I have seen some problems before with eagle product's before , (rod's not the same length etc...) , it just pay's off to double check everything. I would also go a hyd roller cam for sure. I had a 350 in a 78 short bed with a comp. 270 hr cam in it with a true 10 to 1 compression with trick flow heads and it had a nice semi choppy idle and had a great tq. from 1700 up , .215 at .050 dur. , .500 lift , 110 lobe sep. Very fast yet very street friendly. Make sure you know your true compression before choosing a cam and you can get away with a little more cam in a stroker motor
82chevy350
Van Buren, AR
Joey
C10, K10, K5
was thinkin howards
180305-08 NA 282 282 229 229 .480 .480 108 104 Hyd. Hyd. 1
was thinkin howards
Guess I don't get the last 2 specs. The 108 and 104. What are those #'s?
What's the lobe center or LCA on this cam??? Looking like a mild very streetable cam so far. Hopefully a 110-112 degree LCA for low end to mid-range power.
Mark L
Charlotte NC
Mark
1973 & 1986
250ci Inline 6 Baby! & Neck Snapping 305!
SO heres what i got so far
Alluminum RPM Air Gap Intake
Alluminum Dart Pro 1 Heads 58cc with 200cc Runner
1 inch carb Spacer
Flat Top pistons 4 valve relief
Eagle 5.7 I beam rods
Eagle Ext Carnk 383
Balanced flywheel and Flexplate
Crane Cam 1.5 Full roller rocker arms 350 Vortec Block bored .30 over and clearanced for crank
:gr_guns:
Did you buy the rotating assembly as a kit? If so where did you get it, and what did you have to pay for it? I'm looking for the same type wet up.
Uhh yeah Joey, it's time for an update on this build Dawg. Been over 2 weeks now. Where you at on it? Hell, motor oughta be installed broke in, and burning rubber down the track by now. Wassup???
82chevy350
Van Buren, AR
Joey
C10, K10, K5
Lol i still got to get some things
oil pump
cam
lifters
gear drive timing set
carb
ignition systems
water pump
push rods
altenator
82chevy350
Van Buren, AR
Joey
C10, K10, K5
i did buy the rotating assembly as a kit
paid $709 on ebay for it
Driver4r
Nebraska
Trevor
k10,c20
are you going with a loose gear timing set? Or a fine cut set?
Basically, do you want a wine or silence.
82chevy350
Van Buren, AR
Joey
C10, K10, K5
i do want the wine i love the sound
twitch1989
