Oct 30, 2014 #31 Swims350 Full Access Member Joined Jul 30, 2010 Posts 4,357 Reaction score 818 Location Logan WV First Name Chris Truck Year 1983 Truck Model K10 Engine Size none what do the v8 mounts look like you are going to use?
Oct 30, 2014 #32 kleedus Full Access Member Joined Jan 25, 2012 Posts 1,726 Reaction score 164 Location wyo First Name Ray Truck Year 1960 threw 91 Truck Model c10 to k30 Engine Size 350 threw 454 I used the transdapt mounts that use the 2.8 motor mount http://www.tdperformance.com/images/ePIM/original/9906-9926.pdf do not use any mounts that use the 4.3 mount they are week both my original 4.3 mounts were bad when I pulled it out Attachments 9906_1.jpg 16.7 KB · Views: 158 Last edited: Oct 30, 2014
Oct 30, 2014 #33 Swims350 Full Access Member Joined Jul 30, 2010 Posts 4,357 Reaction score 818 Location Logan WV First Name Chris Truck Year 1983 Truck Model K10 Engine Size none aaaahhh crap. I was hoping IF I did this I'd avoid drilling access holes to remove stock frame mounts, dangit.
Oct 30, 2014 #34 kleedus Full Access Member Joined Jan 25, 2012 Posts 1,726 Reaction score 164 Location wyo First Name Ray Truck Year 1960 threw 91 Truck Model c10 to k30 Engine Size 350 threw 454 I got off easy the blazers have a raised pad the motor mount bolts to easy removal
Oct 30, 2014 #35 Swims350 Full Access Member Joined Jul 30, 2010 Posts 4,357 Reaction score 818 Location Logan WV First Name Chris Truck Year 1983 Truck Model K10 Engine Size none that sucks lol for me.
Oct 30, 2014 #36 Stewzer55 Full Access Member Joined Dec 4, 2013 Posts 2,243 Reaction score 66 Location Ohio First Name Stew Truck Year 1988 Truck Model R30 Engine Size 350 TBI There are even some 4.3 guys who swap to the 2.8 v8 conversion mounts for strength.
Oct 30, 2014 #37 kleedus Full Access Member Joined Jan 25, 2012 Posts 1,726 Reaction score 164 Location wyo First Name Ray Truck Year 1960 threw 91 Truck Model c10 to k30 Engine Size 350 threw 454 its stabbed in Attachments 001.jpg 96.9 KB · Views: 107 002.jpg 98.8 KB · Views: 110 009.jpg 100.1 KB · Views: 112 010.jpg 95 KB · Views: 101 011.jpg 93.6 KB · Views: 101
Oct 30, 2014 #38 Swims350 Full Access Member Joined Jul 30, 2010 Posts 4,357 Reaction score 818 Location Logan WV First Name Chris Truck Year 1983 Truck Model K10 Engine Size none I see exactly what you mean above them being raised, great way to show what you said man very easy for you.
Oct 30, 2014 #39 kleedus Full Access Member Joined Jan 25, 2012 Posts 1,726 Reaction score 164 Location wyo First Name Ray Truck Year 1960 threw 91 Truck Model c10 to k30 Engine Size 350 threw 454 and the nuts are factory welded to the raised mount these mounts are the same height as the 4.3 mounts were so my engine sits in the same place just a bit longer on the front
Nov 2, 2014 #40 HotRodPC Administrator Staff member Admin Joined Aug 29, 2010 Posts 47,210 Reaction score 9,482 Location OKC, OK First Name HotRod Truck Year 85 K20 LWB Truck Model Silverado Engine Size 454 - Turbo 400 - 3.73 Which means the trans mount, crossmember, OEM shifter linkage, cooling lines, driveshaft and all that ******** bolts right back in without mods.
Nov 2, 2014 #41 89Suburban Supporting Member Supporting Member Joined Dec 7, 2010 Posts 24,922 Reaction score 7,066 Location Southeast PA First Name Paw Paw Truck Year 2007 Truck Model Chevrolet Tahoe LT Engine Size 5.3, 4WD That's bad ass, great work.
Nov 2, 2014 #42 Stewzer55 Full Access Member Joined Dec 4, 2013 Posts 2,243 Reaction score 66 Location Ohio First Name Stew Truck Year 1988 Truck Model R30 Engine Size 350 TBI Swapping a 4.3 S10 to a v8 is just about the easiest engine swap there is out there.
Nov 2, 2014 #43 kleedus Full Access Member Joined Jan 25, 2012 Posts 1,726 Reaction score 164 Location wyo First Name Ray Truck Year 1960 threw 91 Truck Model c10 to k30 Engine Size 350 threw 454 the only thing easier would be a 3.8 v6 in a vega direct bolt in using all stock gm parts. but that's kinda why I held out for a 89 up blazer with the 4.3 I have had a couple chances to get a 2.8 blazer and passed on them
Nov 3, 2014 #44 kleedus Full Access Member Joined Jan 25, 2012 Posts 1,726 Reaction score 164 Location wyo First Name Ray Truck Year 1960 threw 91 Truck Model c10 to k30 Engine Size 350 threw 454 got the headers and the radiator today got the headers loosely bolted on to test the fit they fit pretty good but I will need to adjust a few things. radiator looks good but I have to go to work tonight so I can't play with it till days off.
Nov 4, 2014 #45 Swims350 Full Access Member Joined Jul 30, 2010 Posts 4,357 Reaction score 818 Location Logan WV First Name Chris Truck Year 1983 Truck Model K10 Engine Size none your 700r4 has a tv cable right? shouldn't they all? I noticed on mine today I see no tv cable at the tb at all.
