1996 corvette zip tie special
yevgenievich
Viktor
sad
very sad
less sad
I should call it charity and write it off on taxes. Save people by making things less questionable(sometimes)
yevgenievich
Viktor
sad
very sad
less sad
Worked on it some and I think it is going to go back for sale. It needs more body work than I was hoping for.
Fixed the hood hinge, that was also bent and reslotted. Got the throttle set back up. Cruise control cable is ruined. Fixed the ecm mount, fuse block mount, realigned one of the headlights. Found that the replacement side cover that was included is for an older 85-90ish model and does not match this one. Also cut some random wires out.
yevgenievich
Viktor
sad
very sad
less sad
And couple of more pictures. Going to change tv cable on it and see if 3/4 are bad in a couple of days. Will have to make a temp mount for the cable as well.
73c20jim
Tombstone, AZ
We got red zip ties, blue zip ties, short zip ties, long zip ties, blue zip ties, fat zip ties, thin zip ties, yellow zip ties, extra long zip ties, UV proof zip ties, easily breakable zip ties, black zip ties....
yevgenievich
Viktor
sad
very sad
less sad
And this is a first for me. I don't know how cheap you are, but at least put an actual tv cable in, instead of rigging up and ruining everything. It might have even lived fine if it was not dumping fluid everywhere.
yevgenievich
Viktor
sad
very sad
less sad
I got a friend that wants those valve covers for his Roadmaster.
Don't tempt me, or this thing will end up in pieces. But I am going to go ahead and throw an actual tv cable at it and see if this trans is actually blown for sure.
4WDKC
Southern Florida
Kacy
Would make a great track car.
I’ve seen a couple guys near me cut all the panels off and turns them into pretty nifty carts kinda like Roadkill and Cleetus McFarland. Seems to be the best thing to do with this gen of vette lol
4WDKC
Southern Florida
Kacy
I’ve seen a couple guys near be cut all the panels off and turns them into pretty nifty carts kinda like Roadkill and Cleetus McFarland. Seems to be the best thing to do with this gen of vette lol
I saw those too
yevgenievich
Viktor
sad
very sad
less sad
This is rapidly leaning towards a part out.
After diving under it, it is barely worth half of what I paid for it. Can't believe there are people out there making this stuff.
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Wait wtf?!?
That's special with a capital short bus there batman.
Holy smokes!! :eek:
yevgenievich
Viktor
sad
very sad
less sad
On the plus side, I found 3rd gear. On the downside, tv cable attachment is stripped and it still pukes oil out when stopped.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
That sux man.:(
Dale Downes
