1996 corvette zip tie special
Moderator
I'd also like to point out, Corvette directional wheels were side-specific. There was a pair of wheels for both directions.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Funny - I have heard of salad shooters on F Bodies
but not on Vettes before .
Oh, the veritable font of information this forum is!:driver:
Britt
Rusty Nail
Cowboy of both Time and Space
Russell
350sbc
Glad you're havin a nice time pal, we all want to make certain that you get your monies' worth!:naughty:
yevgenievich
Place
Name
Year
Model
Size
Someone needs to get a life
yevgenievich
Place
Name
Year
Model
Size
Transmission has been happily dumping it's guts out over last couple of days. Must be coming through cut up tv cable. Some pictures of the horrors. Battery either weak or there is a drain as it would not start today
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Wow after those pics I have a lot of questions
Let's forget that the computer is just flopping on the intake for a minute and start with the fire hazards. That black mushroom cap shaped piece about 3 inches south of the vice grips, the one that has a nut on top and a hose connector on the other end. It's a check valve for the smog and they recirculate hot manifold gasses on lt1's. They can and will get hot, maybe give the wires running across it some clearance.
Something like a zip tie would work. If you can find one.
yevgenievich
Place
Name
Year
Model
Size
The metal tie near headlight motors holds the hood hinge together. I need to go through alot of things under the hood, there are also random wires laying around and battery ready to fall out.
MikeB
Love it when folks paint their aluminum wheels black to be trendy, and then watch as the paint starts to flake off.
You must really love a challenge taking on that POS. :) But sounds like you're on top of things, so git 'er dun!
Moderator Administrator
:rofl: I have never, in my life seen so many zip ties just holding things on!!! I'm almost surprised that the door hinges are zip tied. Oh, motor mounts are bad? better run to O'Reilly and grab some zip ties :happy175:
yevgenievich
Place
Name
Year
Model
Size
You scored a free pair of vise grips too? LOLo_O
Craftsman even! None of that flimsy overseas garbage!
Unfortunately those were mine to get the trans to somewhat work and give it a bit of throttle operation. I did score them with my camaro I believe, as they were serving as a window crank if I remember correctly.
I think I just revealed that I have a habit of questionable purchases.
NateP350
