Joshua Keith
Memphis
Joshua
I wish someone had found mine before the floor board Rust and the side rot out like they do. I fixed the leak and globbed goop (Bondo...) and whatever I could in the rust holes like those of us who don't weld in patch panels do. It works for what it is. Truck was never meant to be a show truck anyway.
Yeah, it was a ton of work, but better to catch it sooner than too late.
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
I say give him a break...
My flux looks like bird poo too.. Ya just can't make a quality flux weld really lol
Sent from my SM-G965U using Tapatalk
Maybe I didn't heat it enough before welding on it. I have never welded anything like that before.
80BrownK10
Greenwood, SC
Nate
Yea I have a super cheap HF flux 120v welder. I know it's cheap. It took me a long while to make a quality bead with it but still looks like crap with the splatter. A few guys told me that's just how it is. I just thought it was cause I taught myself to weld by reading , pictures and videos.
Then I was at one of my loggers shops just BS' ing with him. He said here weld this if your gonna stand there. I said ok. Set your welder up for me. He did and I welded up the pins for his landing gear he was making. My welds I thought looked amazing!! I really did realize it is the flux and my cheap welder. He had a snap on mig welder is what I was useing.
Arkansas_V8
Proud Redneck
Brent
V20 Suburban
Going from AC to DC makes a huge difference even with flux though. I have that same welder you do.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
It's unshielded, which is why it's splatters like hell, like arc
TubeTruck
East TN
Denis
Suburban K10
LQ9
That's a shitton of razor blades, work smarter not harder.
I like it. Too bad we haven't had sun in about a week lol I will try this on the back though. Thanks
80BrownK10
Greenwood, SC
Nate
I didn't understand the bag on the outside at the beginning? Was that for extra heat?
TubeTruck
East TN
Denis
Suburban K10
LQ9
Just to measure the size so you don't have to do it inside in cramped spaces. We wouldn't have that problem in our trucks. I'm going to douse mine with 409, stick the bag to it and cut around it window with a pair of scissors
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Loaded the wifes truck with books for a trip to half price books, and a warmup for the next project.
Damn floor jack is heavy !
Noticed the right drum was HOT last night - the driver's side not.
Wanted to adjust them.
Saw this on the driver's side.
Sprayed it down, cleaned it up, and 20 pedal pumps later , this.
I think it's residual from when I did the wheel cylinders last year.
Poppy 87
Bloomingdale GA
R10 Silverado
Might want to check the flex brake hose to the right rear, they can collapse internally, especially if it's a 30 plus year old part.
Sent from my XT1254 using Tapatalk
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
May not be a bad plan.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
So, got my package from @legopnuematic - thanks, dude !
:waytogo:
Tested it - seems to work !
Decided to install it- 1-1/4 in wrench is hard to swing over the upper hose, but doable.
Trying to get it orientated correctly- then, this happens.
FML
:bawl:
I will have to buy that Standard Auto Parts one now.
Plus side is no antifreeze came out.
Silverado9019
