legopnuematic
Licensed Junk Dealer
MO
Spencer
Gear setup done in the 10 bolt front.
Moving onto the external stuff. Hope to have this wrapped up by the end of the week.
Ontheboulder
colville,wa
greg
gmc sierra classic v2500
Waiting for my new steering box,so doing a rebuild on my Napa floor jack
well now its time to cross my fingers and hope it works!! gotta wait till tomorrow till the sealant sets up and dries on the reservoir surface, then fill it up and see what happens!! Also got my new steering gear box today so after our big -supposed - wind storm tonight I can get going on that stuff!
53charlie
Memphis
Charlie
The lens on the reverse lights is so opaque that even with bright LED lightbulbs I could not see what I was backing into. A pair of bright white LED solved the problem
Camar068
Air Force Supporting Member
10 yrs Air Force
wonder if a good cleaning, then taking a heat gun to the lens if they would "rejuvenate" the plastic? I think I have a few old spares I can try it on.
Ontheboulder
colville,wa
greg
Well after being out helping my neighbors at 4am with down trees in the big storm,what a mess! I got the floor jack filled up and it works! Still have to test it out under the truck to make sure it holds. Trees are down all over the frozen boulder from the storm and now it's snowing this morning! Mother Nature is having a hot flash
Tennessee
Found a decent fender replacement for mine at the junkyard. Just have to weld up the trim holes.
What's the best thing to put on it to kill out the rust? Its just starting to bubble in the bottom rear corner. It's not a show truck and Im probably just gonna spray bomb it with some Krylon thats pretty close for now
shawn57nomad
Midwest
Pulled the box 1 man style getting ready for a C-notch and flip with CalTracs. Any recommendations on a budget friendly rust converter and paint for topcoat? Happy Saturday!
xm20k
Girard, Ohio
Do the flip and see where she lands mine did not need a C notch which works for me as I'd rather not chop up the frame. Just ground down the rivets and knocked the bump stop brackets off. However, I don't haul stuff with mine so there's never any weight in the bed other than the 20-gallon fuel cell. Also, under a hard launch/acceleration even a burn out using the line lock she separates due to the CalTracs.
POR 15 and Eastwood seem to be the most popular rust inhibitors.
Tank6x2
You’re Awesome Know That!
Lifetime Supporting Member
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
Starting to think adhd/ocd are a bad combination to have - should I continue with the cab floor dings or just stop and finish with metal prep:banghead:
Camar068
10 yrs Air Force
had the balljoints changed last year on the passenger side. No issues until last week I went thru some construction and there was a hella bump (at least 6" immediate drop making a hard left turn to get onto ramp). Thought she was falling apart.....but everything settled so I got on the interstate and moved one. A week later, I started getting random fairly solid right pulls doing 60 going straight. Also, noticed random "help" turning in parking lots.
Jacked it up and it had some play top/bottom. Ordered spindle nuts just in case (Warn for $110) , but turned out the outer spindle nut was only hand tight. When I had the ball joints changed the inner spindle nut was broke on one side is why I ordered the spindle nuts.
Pulled it apart to inspect bearings and spindle, all was well except for the loose spindle nut. Cranked it to 120# on assembly and called it a day.
Also got to try out the new Bauer impact ($160 with 5Ah batt and charger). Handled the lug nuts like no business.
