What's this thing in my rim?
bigcountry78
Hickory, North Carolina
James
K10 Custom Deluxe
Can y'all tell me what this metal piece is that visible in my steel wheels? Picked up an 8 inch wide set a while back, and all 4 have this metal piece visible on the outside of the wheel. Ive had many sets of rims but I've never seen this before.
Georgeb
Wisconsin
George
K10 Burb Z71
Weld seam or tooling mark from rolling the rim during manufacturing.
bigcountry78
James
K10 Custom Deluxe
Yep found the weld seam on the inside, with two weld beads.
I think these wheels may have been widened at some point. Measured the back spacing and sure enough, there is different backspacing on two of them. Just my luck.
Georgeb
Wisconsin
George
K10 Burb Z71
I think these wheels may have been widened at soem point. Measured the back spacing and sure enough, there is different backspacing on two of them. Just my luck.
That doesn't look factory. The first pic is and I have seen that a lot but the other beads indicate the wheels were widened at some point.
bigcountry78
James
K10 Custom Deluxe
That's what I was afraid of. Will widened wheels run true? I know people have done it, but in my mind I just don't see how it would be possible. I also don't see any markings at all on these wheels. My rally's have GM stamped on the outside. I'm about to just paint them, and buy trim rings and centers. Thanks for the speedy response.
Georgeb
Wisconsin
George
K10 Burb Z71
Sure they will run true if it was done correctly. You would need to spin them to see if there is a bunch of run out or not. I wouldn't hesitate to widen wheels but I have access to the tools needed.
bigcountry78
James
K10 Custom Deluxe
Well I guess I have to decide if my OCD will let me use these or not. I don't like knowing the backspacing is different.
CSFJ
OCD is a bitch. I feel your pain. Something like that would bug the **** out of me too.
Georgeb
Wisconsin
George
K10 Burb Z71
Same here. I couldn't do it except for a rare occasion and only paired on the front or rear. Then I wouldn't be able to rotate them.
Keith Seymore
Motor City
Keith Seymore
R10
4.3L
I've also widened my own wheels.
They will need to be checked for lateral and radial runout. If they are off less than .015" they will be ok.
K
bigcountry78
James
K10 Custom Deluxe
K
How would I go about checking them? I'm glad I'm not the only one it would bother. I see guys running different sizes and offsets front to rear and mi mind immediately starts freaking out because you can't rotate your tires with those setups. I couldn't do it.
Georgeb
Wisconsin
George
K10 Burb Z71
You could spin them on a wheel balancer at a tire shop or on your truck without tires on them either check by eye or preferably with a dial indicator.
yevgenievich
Place
Name
Year
Model
Size
Front to back different backspacing wouldn't bother me if the fit is good. Just verify the runout as mentioned
twzorek
