Ajax19
Socal
Ajax
New day old truck and new problems front brakes seem to be sticking after I drive a bit Shure enough I pulled in and jacked the front up and took some effort to rotate the wheels I know they were free a few weeks ago when I was checking the front end for some play went ahead and ordered some new hoses and I'll be playing with that when they get here probably a good time to get the new leaf spring bushings in, calipers and pads look good hoses are original it will be good piece of mind atleast
Marine Corps Moderator
Welcome to Squarebodies! If it isn't one thing, it's another. This would be a good time to check your master cylinder, and brake booster, give you that little extra piece of mind. Just my suggestion while your at it....
Got a little more of the passengers side floors started. Also started cleaning up the firewall. Have to fix a spot. Cut out a panel off of the 2wd Blazer. Sand blasted it.... I forgot how much of a PIA cleaning seem sealer out..
Dryriver1
Robert
350 cid, 5.7
Thanks for this! I was thinking of having someone rebuild it if I can't get the right one from the parts houses. We used to have a shop that rebuilt starters and alternators. Don't know if they are still there.
Hello 82sbsortbed! Hope you are doing well.
I just wanted to share this video with you and all the GMSB Buddies. This gentleman explains it really well and without loud obnoxtious music.
He is just direct and to the point.
Check it out. You might be able to save you a litt money and puts you to work on your bench... LOL :D
Have a very good end to your weekend and a good start to your week!
Best wishes to you and all of your loved ones always!
Dryriver1
Moderator
Still screwing with the crew cab. Besides replacing the spring bushings with greasable ones, I've also installed a new stabilizer, tightened/replaced some loose frame and crossmember hardware, along with checked the alignment. Today I also rotated tires and went back to the stock rims on the front (had been running military 36's on humvee wheels, complete with run flats) which has done me no good at all. Previously, it had a high tendency to death wobble and it was bad. Now with the front end improvements, it's actually undriveable. Like, literally can't even take it on the road because once you hit about 15-20 mph it brings on the most ungodly death wobble I've ever experienced. Very frustrating since the front end is tight.
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
Just gonna leave this here . . . if you know it you know it
82sbshortbed
Why like that?
SE Texas
Doug
1500 shortbed, 1500 longbed
Got the starter wired up. Was trying to bolt it up and was having trouble getting it back on. So I took a break because I was getting mad and didn't want to break something. Lol
Well it decided to pour down rain. So that was it for yesterday. Really needed the rain so wasn't to mad about it. Try again when I get home from work.
ChuckN
Bellinham, WA
Chad
Man, that’s frustrating. What’s next then? Has to be something…
Kudos for the Earnhardt plate BTW. Maybe his ghost is in the cab with ya playing with the steering.
Dryriver1
Robert
350 cid, 5.7
Good morning 82sbshortbed!
Keep us posted on that stubborn starter.
At least it was some well needed rain and not a flooding rain.
Have a good week!
Dryriver1
Moderator
I'll probably be wasting time, but my next step was to mess with the king pin springs. Maybe add a washer on each side.
ChuckN
Bellinham, WA
Chad
Ah, the setbacks. Gotta tell myself not to give in. Have to do some regrouping and thinking myself today.
Took the truck in for a new windshield today since it’s all cracked to hell. Lots of underlying rust. So they’re cleaning it up and reusing the old gasket for now since it was perfectly fine. It is garage kept and doesn’t go out in the rain.
The LMC gasket can sit in the box for now until I find someone who can clean up the windshield mounting area.
ChuckN
Bellinham, WA
Chad
It may actually not be that bad once you get it vacuumed up. Hopefully just needs a small patch and some rust converter
I’ve seen worse for sure. Just taking a breath and thinking objectively at this point. I do know there’s a place just north of me that does custom work- next nice day I have I’ll take a drive up there and see what he says. I’m sure it won’t be cheap but it won’t get any cheaper if it sits like this.
Nope. It's just one of those obstacles we deal with when working on these old rigs. I was worried when I got my windshield done (I wasn't here) but my glass guy said it looked good, thankfully. And he and his son both have squares so I trust his judgement
nixon22
