Got the new frame patch cap in from Summit. Ordered it on Friday and FedEx dropped it off on Sunday. Fairly impressed with the overall quality of the piece I got sent. Rust Buster Frameworks coated it in light oil to protect it from rusting but should be an easy clean and prep with some Acetone. Drilled out all the rivets on the spring hanger so the patch section can be put on. Got a better look at the crack and it's not pretty. Few of the bottom rivets were frozen and came out with some frame that was pretty thin. Seen the crack basically ran from the bottom of the rail clean to the top and just stopped there. Luckily the spring hanger held it together enough to get her home.
New piece looks pretty good and fits pretty well. Have to order some grade 8 standard hardware because for some silly reason they sent some M10 Class 10.9 bolts and nuts. Got some Grade 8 3/8-16 hardware coming in hopefully by Friday. This way I can finish getting it prepped and bolted together for a buddy down the street to put some fresh beads on the patch so that I can get her finished up and back together. Hoping to be done by this Sunday for a local show at my daughters old high school to benefit a local PD and their K9 officers.
