Moderator
Didn't expect this. Old painted bumper removing paint with citristrip with saran wrap over it. I've only ever tried 24 hrs then repeat.
Put it on and wrapped sunday. Had the grandkids for a few days so didn't touch it until today. Absolute butter removal.
I got time at that rate. AC remover is better from what I've read, but they say the metal retains the smell for days. Wife would b|tch about it tho lol.
@bucket going clean and smooth on the front and let the rear bumper be the wear and tear look lol. Thx again.
So was there chrome under there or had it been removed?
Camar068
Air Force Supporting Member
10 yrs Air Force
No chrome at all. I think that brown/maroon stuff was a primer of some sort. Instead of scraping, I think I'll set up the pressure washer to make it faster.
Moderator
Since clearing my code 42, I have driven it twice with no check engine light, or issues however I am anticipating it again eventually.
I finally got my ignition control module, which was a first impulse purchase after seeing code 42 and researching what is involved. I also got my MAP sensor connector, not related to the code 42(that I know of). I do need a new connector as my current one is zipp tied to stay fastened. The tab broke off sometime when myself and the shop were troubleshooting my previous rough idle/stumbling etc..
ICM is NOS from 1995, Made in USA. I think this may be the 2nd ever AC Delco part that was made in USA I have managed to land. Still thinking about ordering the AC Delco connectors for the ICM but want to take a better look at them when the cap is off to install new ICM.
The MAP connector is newer, made in Taiwan but looks great. Plenty of wire to splice in with. I saw a video where a guy just pushed the electrical posts out of thw old housing and pushed in to a new connector housing. That looks super easy, but I probably need to splice it in and get the new wires in the system.
Is there a shipping date in the box? I ask because that copyright date of 1995 is just for that box design, which lasted until a few years ago.
Sad Sack
Nebraska
Goober
C15
I used to use steel wool to remove the residue, once the vast majority of the paint was removed. By brushing paint remover on the left-over areas and scrub with the steel wool then rinse off or use a damp rag.
Finkaire
Finkaire
California
Loren
Silverado c10
My buddy only has use of his left hand and always needs help buckling in. I removed the holders years ago not liking having to slide over them. Not aclue whatever happened to them.
Finkaire
Finkaire
California
Loren
Silverado c10
Finished my exhaust. Debating weather I want a turn down at the rear to get it under the reciever hitch or aim the turn down out and down and cut the pipe after the shackle
Check this out, only for stepside and yes that is stock
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Nope, nothing in the box but the module and the conducting lube. And, I threw the invoice out already.
Burkee1483
When did we get ice cream!?
bealeton virginia
mike
Slowly tackling fruitful projects for a win each time I touch the truck. Dragging my feet on dropping the tanks on my back lol
Kitrods
North East PA
Lei
V20 Suburban
Fitted a Red top. Replaced quad shocks. New polished aluminum 4 row Radiator from Summit.
New regulator in the tailgate and new glass wiper seals there as well. I cheated n bypassed the open closed relay for the tailgate motor.
Ordered a ton of other parts from LMC. Seat rail carpet inner front fenders. Will post pics soon. Love being back in the Square
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
If you have them empty (or seriously close) and use a floor jack to slow re-entry, it's not as bad as you might think. I did it in the gravel carport with the jack on plywood so it would roll.
It's nice having that third hand holding it up while you go after the sending unit wiring and hoses (except I would just cut them because now is a great time to replace them anyway). Don't let the fill tube give you fits either, just manhandle it.
You've got this.
Chevrolado
McKinney, TX
Dave
1977|2006
K10|1500
5.7|5.3
You've got this.
I was going to say the same thing.. I kept pushing my tank dropping off as well for as long as I could, then once I did it I was like.. c'mon, really? Why didnt I do this months ago? Easy.
And yeah, floor jack "helper" for the win. Same for when you go to reinstall - set it back on the jack and let it do the "heavy lifting" in place. :D
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Put in the new IAC, as well as cleaned up the TBI and put in new injectors, what a difference!
After that I threw it up on stands, pulled the headliner as it was just disintegrating and crap flew around inside anytime I drove it:D
Then I drained the coolant, replaced the thermostat and the upper radiator hose. Need to do some cleaning before I put a new lower hose in, that will be at some point this week, along with an oil change.
Was it hunting for idle? Our does sometimes and I thought about taking out and cleaning; reset.
jw23655
