Terlingueno
Fictional Western Sage
Far West Texas
Skeeter
K20 Suburban
350/SM465
Got minded that changing an in-line canister filter under the vehicle, regardless of how quickly you make that swap on the inlet side, while the tank is full of fuel, you're getting soaked in fuel. Just the shirt shoulder area and back, but nothing that a change of shirt could't fix...lol...
Did it look like this one I replaced on the frame rail? I never knew it was there until I saw it whilst inspecting stuff underneath, and I have owned this Sub since 1994. This one was probably installed during assembly in 1985, and yes, I took a gasoline hand/arm/shoulder bath during the process a couple weeks ago...
Marine Corps Moderator
Got the serpentine belt components installed and did a test run. All seems well.
Installation wasn’t a real big deal. The biggest issue I had was entirely my doing: I pressed on the new power steering pump pulley backwards. Of course that made removal a challenge as there was no provision for the tool to remove a backwards pulley, lol. I modified a steering wheel puller and with a bit of heat was able to get it off.
They did send the wrong belt (belt was for engine with air conditioning) but measured and got a suitable belt from Oreilly’s.
What system is that?
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
Probably where the rifle rack was at...
@bucket
The rifle rack is behind the driver's seat. I had actually stumbled on an M1009 for sale last night on Marketplace and it was VERY clean and completed - had the same bracket with a fuel jug mounted to it.
Ontheboulder
colville,wa
greg
gmc sierra classic v2500
well I am gonna bite the bullet and order up a redhead steering box. input shaft seals are squirting oil pretty good so Not gonna mess with trying to seal it up since I am sure its probably the original box or a cheap replacement.
Travlr
Central Utah
C
K20 Camper Special
@bucket
That's a water can. I have one of them...
Tank6x2
You’re Awesome Know That!
Lifetime Supporting Member
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
Can you share the part number for the Led relay's plz! Or a pic, website!
Time to install some 1/4 turn valves
Tank6x2
Kurt
C30
Started the weekend getting the mill scale off - leftovers from lasering, cleaning off residual tight spot rust it couldn’t reach, good weekend!
bigy8s
