Great info, thanks bud.
It's a shame, cuz it does look good cleared. Just doesn't last. My buddy had his '86 polished (Rick, SQRBDY, the red and white single cab if you ever watch the UBT road trips) and ceramic'd like I mentioned and it looks fantastic, even 2 years and many miles later
yeah, the data report out speed is about every 0.8 seconds, so it is pretty slow. the actual ECM is making changes much faster. so it does help, but it isn't a perfect diagnostic tool.
as long as you don't enter diagnostic mode on the cable/scanner (it should come with directions of some sort on that topic) then watching the data via a cable while the engine is running has no impact on what the ECM is doing. or at least that I can ever tell on mine.
depending on the cable in use, if there is a resistor shorting between two pins (forget which ones, and a lot of them internally do this on the plug. i believe its the one that does field service mode, memory not the best on this)
I was referring to the tach readout would be laggy behind a hand held tach but good to know its only .8 sec
my 1990 olds 88 has a tach readout, and it doesnt seem like a long time but its slow enough that its noticeable
mxer147
Colorado
Jack
k20
Thought about spraying it but too much work for an area mostly hidden, plus if I can avoid the toxic paint I will every time. After this one dries I will brush on the second coat.
Johnny Atomic
Little Rock AR
Johnny
Sierra Classic 1500
Finally got tired of how bad the tops of my door panels looked any time it rained/they got water on them, so I treated them with leather/vinyl conditioner. They were SUPER dry, idk when the last time I treated them was. I need to get better about that before they dry out and break
I've got a really crazy fix for this that I'll tell you about, but don't want to announce it publicly yet.
Moderator
Heating the plastic with a heat gun or torch?
Swapped my front tires from side to side cuz I’m getting pretty low on the insides and the LH wears worse. Gotta buy a little more time
LH - RH. So I flipped ‘em, maybe I can get another 2-3k miles lol
Also…dirtyyyyyy
Camar068
Air Force Supporting Member
Kentucky
10 yrs Air Force
had the mufflers changed and a few leaks taken care of today. Man I miss my cheap guy. I found out why he was so cheap tho.....he's gone down hill health wise due to life choices.
Anyway, world of difference with sound and throttle response (I think), we'll test it out more tomorrow.
williestreet
Halifax, Nova Scotia
I picked up a set of Rally wheels a couple of weeks ago and have been spending some time getting them sanded down and painted. Definitely not perfect but I think they will look decent when finished. I found some 3 inch trim rings, but would prefer the narrower 2 inch. Hopefully I can find a decent set in the future. After a few days more curing I will swap my tires over and see how they look on the truck. If I don't like them I will probably just paint them black.
82sbshortbed
Why like that?
SE Texas
Doug
1500 shortbed, 1500 longbed
Got the tach mounted with double sided tape and two wraps of electric tape. That's the best way to get around the box at the turn signal handle. Not perfect but not too bad.
Cut a notch out for the wires to go thru.
ChuckN
Bellinham, WA
Chad
Spent some time finishing up the baffles for the Mickey Thompson valve covers. I did a test fit, but the grease I placed on the top of the rockers contacted the baffle. Which was weird to me because the old Edelbrock are shorter, the baffle just as low, no issues.
Well, damn. Edelbrock was smart enough to place the baffle between the rockers instead of OVER them. So after going to town and struggling to find breather grommets (turns out they use 1” Ford size) I still don’t have these things on. Honestly, I don’t know how I get myself into these situations, lol.
(Well, my dad would say, “that’s hotrodding Chad!) :anitoof:
The Right side of Washington
Yeah, agree with @TotalyHucked. If you really want it more shiny I might give that patina juice stuff a shot. PS, alot of RV folks swear by Zep floor polish. It was a thing before the patina juice and I wonder if it’s the same. Wipe it on a faded painted or gel coat surface and it lasts a year or more in the sun.
But have you actually polished it yet? It doesn’t take much if it’s old original paint. That stuff is really soft comparatively. Rubbing compound is too harsh. Use polish. And if you don’t have an actual polisher, as quick as it shines up, you could easily use a bonnet attached to a drill motor.
ChuckN
Bellinham, WA
Chad
The paint is a mismatch of different types of paint, and is amateur at best in some area. Maybe not rattlecan, but definitely rough to the touch. I did try VGG’s shine juice once but I messed up the application a bit, might try that again.
Have you seen redbeards truck? Boiled linseed oil
ChuckN
Bellinham, WA
Chad
Not seen that one yet- she’s a beaut!
VGG Shine Juice is partially linseed oil, along with some other stuff to make it more durable. I think it’s available in matte or gloss. I have the gloss version.
