brooksman9
Olive Branch, MS
Patrick
Silverado & Custom Deluxe
350 & 305
I could use one!
Installed a new radiator to replace the leaking like a sive one that it came with. Test drive went much better today. Still have the crank issue. May have to bite the bullet and get a new battery.
WFarm
Central Virginia
K5 Blazer
My drivers door has always been a PITA to close all the way. I hate slamming doors or anything else for that matter, but that’s what it took to close it all the way. Then I found the thread here about using 1/2” PEX to make new sleeves for the door catch. Some of my original sleeve was still there but not much.
Bought a stick of 1/2” PEX and made and installed a new sleeve. HUGE improvement!! Door shuts normally again!
Plus I have enough left over material to make replacement sleeves for the next 1268 years.
82sbshortbed
Why like that?
SE Texas
Doug
1500 shortbed, 1500 longbed
Got the 1156 led bulbs in for the reverse lights today. Had 1157 but they won't fit because the little tabs are offset instead of straight across. I'll show pics latter to compare to the old ones. A little smaller but the 1157 was bought years ago so design and technology has improved probably idk.
The Right side of Washington
Another little easy trick is, if your striker is actively dragging on the door latch (the flat shiny spot on the top), assuming your hinges are in good condition (which I’m sure they are on that beauty blazer), just shim out the bottom door hinge slightly. You won’t notice anything different in the door alignment but it will pick up the door just a tad and not drag on the striker.
Both my squares doors shut so nice with pex sleeves and hinge shims.
Only thing is both drivers doors (used 10x more than passenger side doors I’m sure) have a much more metallic sound when latching and the passenger doors are a friendlier muted sound. But I think that would require replacing the latches with new ones
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
So, drove it to the cruise in yesterday, and that was fun but it sure had a couple moments on the way there when the gas wasn't going again. When we left it didn't have a very good sounding ignition, but drove home better than on the way to the show. When warming up to go to the cruise in it was idling very healthy. It idled high when we pulled back in the driveway and never really came down.
So now I will be looking for anything obvious this afternoon and searching through the threads for next steps.
Oldbear42
Linden, Alberta, Canada
Shaine
C20 LWB Scottsdale
Hauled leaves and other yard waste to the dump. Brought +3 yards of fir wood mulch home for my wife's flower beds. Drove across town (3 blocks) for a volunteer appreciation steak BBQ - with a stop at the local liquor store - then sat on the tailgate, enjoying the beer and talking with the BBQer (my cousin). It was a busy day yesterday.
82sbshortbed
Why like that?
SE Texas
Doug
Adjusted the 84's tv cable so it kicks down when I punch it. Seems to shift better too when I drove it around town. Stopped by advanced auto and got another Bosch 2 5/8" tach. This ones for the 84's steering column.
ChuckN
Bellinham, WA
Chad
Bilsteins are on, and thanks to @Ricko1966 the tool idea to pop the lower ball joint out worked perfectly. So I was able to get the coil spring spacer to level out the ride, sits just about perfect now.
Strangely, one of the KYB Gas-a-just shocks I was replacing exploded and puked all its oil contents onto the ground as I was removing it. Who knows, maybe faulty, maybe it didn’t like being on a lowered truck. Either way, hope to have a chance to test ride tomorrow to see the difference.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Pulled the air filter off and looked around in there. TV cable still connected. IACV, TPS, EMC, and all other electronics still plugged in and ready.
So then naturally as a dude does, I went on the 'set base idle' path and decided I was going to get my engine idling as it should. A big handfull of y'all know this drill...I pulled out my OBD1 computer- paper clip. Jumped A and B ports in the trucks OBD1, turned the key to 'on' for 30 seconds, listened for the IACV needle to do its thing, turned key to 'off'. Unplugged IACV, cranked her up. I think I turned it a quarter turn...about 3 different times, not sure exactly why, it just felt right. Turned the truck off and reconnected the IACV, disconnected the battery for about 5 minutes while I cut squash up for dinner. Returned to the truck, reconnected the battery, cranked her up and she was high idle for about 1.5 seconds and then dropped low and sounded great. I took her around the long loop in the neighborhood and she drove very well.
I love paper clip OBD1 !!!!!!!!!
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
So then naturally as a dude does, I went on the 'set base idle' path and decided I was going to get my engine idling as it should. A big handfull of y'all know this drill...I pulled out my OBD1 computer- paper clip. Jumped A and B ports in the trucks OBD1, turned the key to 'on' for 30 seconds, listened for the IACV needle to do its thing, turned key to 'off'. Unplugged IACV, cranked her up. I think I turned it a quarter turn...about 3 different times, not sure exactly why, it just felt right. Turned the truck off and reconnected the IACV, disconnected the battery for about 5 minutes while I cut squash up for dinner. Returned to the truck, cranked her up and she was high idle for about 1.5 seconds and then dropped low and sounded great. I took her around the long loop in the neighborhood and she drove very well.
TBI Disclaimer for GMSB folks that don't have regular TBI fun.
Original
