Doppleganger
- May 24, 2019
- OH-MI: Just like it sounds
- Chris
- K20
So I'm getting the holes drilled and such for the VA air it will eventually have - with no dash in the way its alot easier. They give you a plate/template for the heater and ac hoses. Mine has a block off for the whole right side (cleaner looking). I transferred the hole location to the firewall as I dont need their plate. 1 hole is 5/8''; 2 holes are 1-1/4" - easy enough. But 2 of them mic at .920 (59/64?). Anyone else encounter this - and if so, what did you use? I would go 7/8 or 1" if I thought there would be no issues.
FWIW: used a step drill to get it close then a cone shaped grinding stone to get it exact.
