Uh oh...
82sbshortbed
Why like that?
SE Texas
Doug
1500 shortbed, 1500 longbed
Man, I was doing some numbers on this and came up with. 17 oil changes a year (1 every 3 weeks)at about a $1,000 doing them yourself.
52,000 miles a year at 5 days a week.
1 tank of gas every day at about $50 which is about $1,000 a month in gas.
You must really love to drive that square and I think that's great but, I could never even come close to affording that. Lol
Glad you can. Must have a great job that pays a ton. Ever think of moving closer to work?
eskimomann209
Modesto
Marcus
I’m on something called an extra board. I don’t work daily. I protect call offs. Still get paid daily. Sometimes I work every 12 hours. In that case I stay gone. For a few days at a time. I also protect a terminal. About 40 miles away. Jobs weird. I guess sometimes I’m regular. Then I do drive it daily.
eskimomann209
Modesto
Marcus
Couple more pictures. Guys think the pinion gear is ok?
Chipped on the very edge from that bar falling into it.
CoggedBelt75
Oklahoma
Joe
With my vast shade tree knowledge :confused:, from what I see, it looks good. Just file down any burrs that may be there. I’ve had worst without issues. Hopefully not much trash hit the bearings.
eskimomann209
Modesto
Marcus
I Actually didn’t put much thought into the pinion bearings.... hmmmmm
350 w/203
If you're gonna re-use it, I'd install a magnetic fill plug!
eskimomann209
Modesto
Marcus
Looks like I’ll need new bearings all around
Siiigh. I hate setting pinion preload. Don’t even have a crush washer handy
78C10BigTen
pennsylvannia
C10 BIG TEN
Im now in your boat.... about to venure into uncharted territory!
eskimomann209
Modesto
Marcus
Driver side carrier. I keep cleaning. Flakes keep coming
eskimomann209
Modesto
Marcus
This looks like it was spinning. Probably toast huh?
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I'm going to do my 14ff with different guts sometime soon. Nice thing about the 14ff is no shimming to set side preload and external shimming for pinion depth--good first axle to do for a newb like me. Good luck
eskimomann209
Modesto
Marcus
Well I’m reusing the gears so I shouldn’t need to re shim. That carrier shim has some good meat that I can mic to get the original thickness to replace. Just annoying I went from replacing a carrier to a complete rebuild lol.
The pinion bearings actually looked good but since they’re out I’m going to replace them.
350 w/203
Well, the bearings are toast. And even with a chip off the pinion, that force could have caused minute cracks elsewhere.
You'll have to give the entire housing a good flush and I'd still use a magnetic filler plug on the rebuild.
Keep us posted.
Original
