sqaurebodyrestore
- Aug 17, 2019
- Armada Michigan
- Dale
- Jimmy
I replaced the steering column in my 1986 GMC Jimmy with a tilt steering column from a Jimmy that was a different year. Everything went in OK but I noticed that at the bottom of the steering column, just before passing though through to engine side, the tilt steering column that I put in has the big white plastic piece just like mine but the tilt column has two different spots where electrical plugs connect to it. As I went and looked back at the original non tilt steering column, there was only the one plug where there was a plug with an green and purple wire attached. Since there was the same spot where my original plug was plugged in, I just plugged in the plug in same spot and left the other one with nothing going to it since my original did not have that plug or a harness for it. I attached a picture of the non tilt steering column with the plug attached. The additional plug was to the left of where the one in picture is located.
Does anyone know that those plugs are for??
Is it OK to leave the other one alone and just plug into the one in same location as my original steering column.
Any help would be appreciated..
thanks in advance.
thanks in advance.
